How do you mount your side skirts
Old Apr 24, 2006 | 04:26 AM
Petrus's Avatar
v e i l o c i t y
How do mount your sideskrits?
I drilled 2 holes on each side of the skirt and mounted it inside each wheelhouse with the OEM plastic clips. Works fine. But then, I used 2 component epoxy glue to attatch it against the door sill. This doesn´t work very well, so I´m curious what you other guys used for this area?
Old Apr 24, 2006 | 12:51 PM
kwescott's Avatar
One ball, corner pocket
I have the MS side skirts and it had the clips you are referring to, as well as four additional holes along the front side of the car, as well as four in the undercarriage. The kit fit perfect when it was first installed. All of the clips from the side have fallen out, and most of the ones in the undercarriage are gone as well. I have had the kit for over 14 months....I just check the clips/bolts in the wheel wells every now and then to make sure they are tight.
Old Apr 24, 2006 | 02:10 PM
FABRO's Avatar
Registered Ricer
So hows the fitment now with just having the bolts on the wheel wells? This is what worries me about buying the authentic MS skirts as opposed to the replicas. I know the replicas don't come painted but they are a whole lot cheaper and seem to fit just as good.
Old Apr 24, 2006 | 02:48 PM
kwescott's Avatar
They fit tightly, but there is a slight space between the skirt and the car. The only advantage the MS kit may have it that they are stiffer than the Urethane replicas....which may sag a little more and may have larger gaps. The MS skirts also have a black spongey material along the top edge which helps to disguise the "gap".
Of note though, this is on my Brillant Black...it may look different (more/less noticeable) on other colors.
Mikeb has the replica body peices and has had the kit on for a longer period of time. You may want to send him a pm to get some feedback on how fitment is on his Velocity Red.
Old Apr 25, 2006 | 09:12 AM
Petrus's Avatar
v e i l o c i t y
HEY KWESXOTT!
>What rims are those? THEY ARE FU****G AWESOME!!!
Old Apr 25, 2006 | 12:24 PM
kwescott's Avatar
Volk GT-7's in Diamond Black.
Attached Thumbnails How do you mount your side skirts-kwescottsunrise2.jpg   How do you mount your side skirts-utah4.jpg   How do you mount your side skirts-utah16.jpg   How do you mount your side skirts-utah20.jpg   How do you mount your side skirts-utah21.jpg
Old Apr 28, 2006 | 12:55 AM
presequel's Avatar
ay bay bay
those rims look great. size, offset?
Old Apr 28, 2006 | 01:44 AM
kwescott's Avatar
here's the link with all the info.
https://www.rx8club.com/showthread.p...+diamond+black
Old Apr 28, 2006 | 01:54 AM
NgoRX8's Avatar
i needa get newer 3M tape. is 3M double-sided tape from autozone and such strong enough? I tried it, but it didn't seem to work that well for me, maybe someone else had better luck
Old Apr 28, 2006 | 02:32 AM
kwescott's Avatar
There is an "industrial grade" product out there that should work. When I watch shows on tv, the body shops usually have 3M as well as some sticky black tuff they lay down when putting on side skirts. Don't know what that is.
Old Apr 28, 2006 | 01:37 PM
MazdaManiac's Avatar
I used a nail gun and a rubber mallet.
Seriously though, the tape that comes on the MS skirts is only sufficient if you really get the mounting surface super-clean and the temperature is high (and the body clips are tight).
After a year, my tape has given up and there is a slowly growing gap between the middle section of the skirt and the sill.
I'm gonna remove them at some pont and use the 3M 2-part trim epoxy instead of the tape.
Old Apr 28, 2006 | 01:49 PM
NgoRX8's Avatar
ouch...
Old Apr 28, 2006 | 02:10 PM
kwescott's Avatar
ok Ngo, where did you guys get those animated RX8's for your avatar. They are starting to grow on me
Old Apr 30, 2006 | 08:42 PM
FABRO's Avatar
Registered Ricer
Does anyone in here know how much or have an idea at least of how much the dealership would charge to install the MS sides? Im just curious to know because I would imagine that it would be a biatch to try and install these pieces by yourself.
Old May 1, 2006 | 01:44 PM
kwescott's Avatar
I installed them myself. And yes, it was a pain because each step you did, you have to do it twice. An additional pain in my install, was that I only had one scissor jack...so I had to do the install in sections as I had to constantly reposition the jack.
Mazda dealers were quoting 2-3 shop hours....so multiple this by their hourly rate to get an idea of how much they will charge you.
Old May 1, 2006 | 02:02 PM
FABRO's Avatar
Registered Ricer
so roughly about $180 to $200, what a rip off!
Old May 1, 2006 | 02:08 PM
NgoRX8's Avatar
I made it. photoshop and imageready
Old May 1, 2006 | 02:12 PM
what animated avatars??
Old May 1, 2006 | 02:14 PM
Olorin2's Avatar
If you've never done anything like this before and try to put the MS sides on yourself, you'll know why bodyshops charge so much. It was worth it to me to save the money and put them on myself, but it took me the better part of a day. Of course, I took my time... but damn, what a royal PITA.
Old May 1, 2006 | 03:07 PM
kwescott's Avatar
I beleive the shop manual says 6 hours for the whole kit.
Old May 1, 2006 | 09:36 PM
FABRO's Avatar
Registered Ricer
Im only getting the sides on, I think the front and back part would be easier espically if you were gonna do it by yourself. Now Im starting to think I should get the front now hmmmm.... . I really don't wanna get the rear since I don't trust anybody from behind. I already got rear ended twice in my 8 damint! Once in a parking lot and they ran away and another time by some 16 year old kid. I wasn't thinking at the time, but I shoulda made his insurance get me a new MS rear.
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
05rx8mazda
Nov 28, 2015 09:42 AM
thewatcher101
Sep 18, 2015 01:48 PM
mitchrx8
Sep 13, 2015 08:05 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
