Racingbeat Springs Istallation double check.
Old Apr 22, 2006 | 09:43 PM
NoPistonsHere's Avatar
RevBeeper
How would I know if the car got lowered .5 of an inch? cause it looks high, I asked the installers if they followed the Directions as in Reassemble the suspension in reverse order, with one exception! do not fully tighten either of the upper link inner ends, or the shock lower attachment bolt- just install the bolts "finger tight Lower the car to the ground and perform the final tightening after pushing down on the chassis to seattle the car. This method of tightening is difficult but important. If you tighten the rubber bushings with "Droop" the bushings can be over stressed and the height will be incorrect.
Well it looks like its factory height, but it is hard to tell cause its only being lowered .5 inch. How will I know for sure that the installers followed these directions, I asked them and they said they did, but I want to double check for sure.
Old Apr 22, 2006 | 09:50 PM
Winning 8's Avatar
Hot Pit
if you measure the before, you will know if there is any different.
some times spring will sag a little after a few weeks.
Old Apr 22, 2006 | 10:01 PM
tiggerlee's Avatar
May Cause Anal Leakage
.5 is not that significant unlike 2" it's not going to be that noticable. I measured my ride height before and after I installed S-Techs and Koni shocks. I then measured it at random to see if any settling had occured.
Old Apr 22, 2006 | 10:04 PM
NgoRX8's Avatar
yes, the springs will have to settle for a few days. .5 of an inch is hardly noticeable when you install, but check in a few days to see if it has gone down.
Old Apr 22, 2006 | 10:18 PM
FABRO's Avatar
Registered Ricer
it takes a few days to settle. Took my RB's awhile and it was making me paranoid as well but you will notice a slight difference in a few days espically if you park next to a stock Rx-8 and look at both vehicles from the rear.
yurcivicsux
192
Sep 12, 2017 10:54 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
duworm
Oct 1, 2015 04:57 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
