looking for black spray paint to paint the intercooler.
Old Apr 22, 2006 | 03:03 PM
stickmantijuana's Avatar
Unregistered User
i'm looking for some good heat-conducting paint material i can spray onto the greddy intercooler to paint it black. or any shop that can anoidize it black in so-cali.
any recommendations?
thanks all.
Old Apr 23, 2006 | 02:58 AM
do not paint it, you want to have it anodized which will require taking it to a plater, it can be done at home but I would not recommend it because it involves some nasty acids and other chemicals
Old Apr 23, 2006 | 11:40 AM
OfficerFarva's Avatar
Yea, I looked into it before cus I had the same Idea and then I was like f that.
Old Apr 23, 2006 | 01:16 PM
Daver's Avatar
More Cow Bell
paint is cheap and will work so I did it. , I only did one side so I can always flip it around if I get tired of it. go for it man. I used black double flat high temp paint, if it gets dinged up all I have to do is spray that little spot.PS I know I’m missing a bolt on the bottom skirt, I have to buy it because I lost it.
Attached Thumbnails looking for black spray paint to paint the intercooler.-daves%2520photoshoot%2520%25288%2529.jpg
Old Apr 24, 2006 | 03:01 AM
I read somewhere else that somone got their intercooler anodized black for $65
paint is cheap and easy to do, but it's a coating and may inhibit heat transfer, even using a heat transfer paint is debatable ... anodizing is simply an oxide dye so the intercooler still functions the same as unfinshed aluminum
Old Apr 24, 2006 | 07:17 PM
Daver's Avatar
More Cow Bell
I feel yah but this was 7 bucks and the intercooler is cold to the touch on the cold side, it looks clean and I dint have to wait, hell I painted it wile it was on the car. I isn’t no expert, hell I don’t really have a much of a clue on what I’m doing but it works, and that’s good enough for a simpleton like me.
Old Apr 26, 2006 | 03:28 PM
Richard Paul's Avatar
I think someone is wrong here. A basic rule for heat transfer in materials is that it relates to electrical transfer. This isn't 100% true all the time but mostly. Anodizing will not transfer electrical current. True it is very thin but if you ground your battery to an anodized surface your car will not start.
Paint on the other hand will work to help remove heat. That is why radiators are not natural but painted a flat black. That is why the SR-71 is painted black. Kelly Johnson did not want to do it because it was extra weight. He could have anodized it with no weight penalty. They took about 80f (I think) off of the surface with this trick. Of course they are talking about 900f to start with.
BTW that temp increase is due to pressure. So you see there is no way to get around compression producing heat. Even at 100% efficiency. On top of that they are working with air temps starting at minus 70f
I use VHT satin black header paint myself.
Old Apr 26, 2006 | 05:24 PM
BigOLundh's Avatar
#1 Legend
Interesting, i may just end up painting mine after all.
Next time i have to take the bumper off... i might as well do this also.
-hS
Rx8 VA Guy
Jun 4, 2016 12:42 AM
Paracleet
Feb 2, 2016 08:25 PM
FubarI33t
Sep 28, 2015 08:45 PM
GK1707
Sep 27, 2015 07:33 PM
drlubell
Sep 26, 2015 11:58 PM
