Havx
04-20-2006, 11:56 PM
Hi there,
If anyone can give me advice on my problem -- please do :bowdown:
I installed the following components into my 2005 RX8 base model
Audiolink Ipod kit
Infinity Reference 5x7 component 90 rms @ 4ohm
Infinity Reference 6x9 100 rms @4ohm
Audiocontrol LC6 (to get a signal to my amp)
McIntosh MC431 100 x 4 @ 4ohm (switchable to 2-3-4 channel and newly repaired by McIntosh from a professional installer that blew it up a long long time ago)
Ok I tapped the audio signals coming from the Stock non-Bose HU using the wiring guide on this forum and ran it to the LC6 input speaker terminals, and used the rear accessory wire as a remote, the LC6 has a remote in and out which goes to the McIntosh amp.
I took my time and wired everything properly and everything looks good even running new speaker wire from the front doors with upgraded 16gauge speaker wire to power them up from the amp.
The problem is the amp I believe, it has a "powerguard" feature that cuts the amp out when clipping occurs, therefore preventing the speakers from being destroyed.
When I turn on the vehicle or reconnect the negative terminal of the battery the amp and LC6 turn on but there is a slight pop sound coming from the speakers. The power light on the amp is on but the "powerguard" is also on, so no audio. The amp has onboard breakers so I power off my car and reset the amp. Once again when I turn on the vehicle the pop sound occurs.
I got the car to work 1 time during the initial install on a fluke after I took a break, everything worked fine, then when I went ahead to put the car together I disconnected the negative terminal to save my lights and any other mishaps that might occur, and when I reconnected the negative terminal on the battery the pop sound is back..... there must be some error somewhere but I cannot figure it out
Everything is grounded properly, to the chassis (scraped the paint a bit to get a good ground), and the LC6 looks good and a signal is coming out.
I tried making a relay from the accessory plug wire being tapped using a 30amp relay to get a 3.6v signal to the amp's remote wire terminal and for the LC6-- no difference.
If anyone has and information or experience with McIntosh equipment please help I spent 3 days in my garage installing this stuff and trying to get this thing to run.
:confused:
Audiolink Ipod kit
:confused:
