Amp and sub installed now car has hard time starting
Old Apr 20, 2006 | 12:46 AM
laudig's Avatar
hey my peoples whats up just recently purchased a Mazda rx8 and installed an amp and sub and now for some reason i have to crank the engine more just to start it, i thought it was the battery so i replaced that and it helped on the cold starts but was the same after that, then took it to mazda for spark plugs upgrade and still the same problem. Anyone have any solutions to this problem
Old Apr 20, 2006 | 12:54 AM
ЯX-8's Avatar
What type of battery did you purchase? Optima battery is the best way to go, just my .02
Old Apr 20, 2006 | 01:18 AM
laudig's Avatar
it was a duralast gold
Old Apr 20, 2006 | 12:41 PM
belkjz's Avatar
do you turn off the radio before starting it. and you may want to get a capacitor if you dont have one.
Old Apr 23, 2006 | 01:54 AM
laudig's Avatar
if i turn off the radio the car turns of good most of the time but sometimes it still messes up, and as far as the capacitor why should i pay more money if they didnt hook it up right i would just like to see if anyone else had this problem and what they did or if someone has experience in installing amps if there is a certain way it should be installed on a Rx8
Old Apr 23, 2006 | 02:06 AM
Winning 8's Avatar
Hot Pit
try to turn the key to on first for a second then start. may be the fuel pressure isn't high enough so you have to crank it for a longer time
Old Apr 23, 2006 | 11:49 PM
forbidden's Avatar
Disconnect the fuse at the battery and try starting again. If it is still hard starting, then the audio system is not the root cause of the problem. If it is not hard starting, reconnect the fuse in the main power wire. Next with keys out of the ignition, go to your amp and see if it is on or off (actually do this anyways). If it is on then you have a constant drain on your battery. List the gear that you have installed and how it was installed. By this I mean how was it connected to the stock audio system, dit it use a LOC and if so how was it powered?
Old Apr 24, 2006 | 10:34 PM
laudig's Avatar
well after taking it to mazda and the problem was still happening i unplugged the amp for a couple of days now and the car started perfect so i let circuit city know and so i gave them my car and they said they changed up the wiring on the ignition and also put a relay on so will see if that corrects the problem
rotarywanker
Dec 8, 2022 05:56 PM
delicious_dallan
Jan 17, 2020 09:17 AM
dbarber
Jul 25, 2015 01:34 PM
dmac1961
Jul 24, 2015 11:27 AM
Kangarhew
Jul 18, 2015 08:27 PM
