help with radio
Old Apr 19, 2006 | 10:58 PM
019ebx's Avatar
help with radio
can some one help i was trying to install the ice thing for my ipod and i shorted the radio and i dont know if its a fuse the ac works but the display and the radio dont work does some one know where the fuse is? can some one help me
Old Sep 4, 2006 | 09:56 AM
jsgates's Avatar
You too?
I have the same problem after installing my Harmon Kardon Drive + Play everything works except the radio and the LEDs on the A/C recirc button area.
Old Sep 4, 2006 | 02:25 PM
jsgates's Avatar
Fuses...
Grab your owner's manual and have a look at the fuse box diagrams. Fuse box is near your left foot if you are sitting in the drivers seat (kick panel area). Pop off the cover and follow the diagram in the manual to check for blown fuses. The radio fuse is a 7.5a fuse in the inside fuse box. You also may have a 20a fuse. I do not have this fuse, so I'm assuming it's for the Bose system. Also, you can check the main fuse box under the hood. It is on the front right side under a plasic cover (if you are standing in front of the car.) I am having a very similar problem and would like to work with you to resolve these issues for the both of us. I have installed 15+ car stereos, and have done several iPod integration projects in the past. I have NEVER run into an issue like this before. Gotta love Mazda's electronics! Give the fuses a try and post your findings. We WILL get to the bottom of this issue.
Old Sep 4, 2006 | 03:48 PM
jsgates's Avatar
Power Problems...
I'm not sure how Icelink installs, but if you are using the cigarette lighter socket as a power source, try disconnecting that and see if all of your controls work again. This solved my problem. See my thread Harmon Kardon Drive + Play install for more info. I hope either of my suggestions solves your problem. Let me know how it turns out.
Old Sep 4, 2006 | 04:41 PM
jsgates's Avatar
well...
Ok, that's not it! With the radio partially out, push on the wires going into the power harness that connects to the back of the radio. Mine appear to be loose and this is causing my issue. Give that a try. If they would give you more slack in that harness, this would not be a problem.
nadodave
Aug 28, 2019 05:55 AM
RX8mzda
Oct 1, 2015 10:17 PM
Learners_Permit
Sep 27, 2015 07:38 PM
CMRine04
Sep 23, 2015 09:31 AM
just1jack
Sep 9, 2015 04:45 PM
