RP/BONEZ Supercat questions ...
Old Apr 19, 2006 | 09:03 AM
Dro's Avatar
Dro
I hear this ****** thing is loud, that is fine with me. My MS dual exaust can get loud but I would like it to be a little more offensive
MY first question is, will this thing mate up w/ my MS midpipe thing or does this actually replace that ? Second, I would like to install this myself, how difficult is it ?
[yes I searched]
Old Apr 19, 2006 | 12:17 PM
Petrus's Avatar
v e i l o c i t y
Cat installation is done in under 30 minutes. Just remove the stock one and replace with the new one... it´s really that simple
Old Apr 19, 2006 | 12:25 PM
the rp cat requires an extra exhaust hanger...someone correct me if im wrong.
Old Apr 19, 2006 | 12:42 PM
Dro's Avatar
Dro
I thought I read that due to the light weight of the RP cat it does not require any hangers ?
what about the compatibility w/ my MS cat back system ... it looks like this thing replaces the whole front piece thing thing
Old Apr 19, 2006 | 12:52 PM
baysj's Avatar
Does the RP Supercat require any ECU tuning? The FAQ said midpipes do. I know this is still a cat but will the higher flow require tuning?.
Old Apr 19, 2006 | 12:56 PM
RA-Eight's Avatar
Scuderia
Some people have had issues with rattling or banging up against the body and had hangers welded on. Some said said what you pointed out, no issues because it had little give, and is lightweight.
It replaces the stock cat. It "should" be compatible with most cat-back.
Old Apr 19, 2006 | 01:25 PM
Dro's Avatar
Dro
alright thanks, im gonna give them a call
Old Apr 19, 2006 | 03:41 PM
Dro's Avatar
Dro
well I called RP and they told me it will match up fine, I ordered it and the gasket/bolt kit
cant wait !
Old Apr 19, 2006 | 03:58 PM
Mazda-Rati's Avatar
the WANKEL made me do it
I've heard people with RB cat-backs are banging with the RP cat w/o the hanger. otherwise I would get one
Old Apr 19, 2006 | 04:46 PM
Dro's Avatar
Dro
On that note, the guy from RP told me that soon they will have a hanger kit in stock for anyone having problems w/ the mid-pipe banging.
There is also always the option of having the stock hanger cut off and welded back on, if you know somebody good like that [and I do, just in case]
Old Apr 19, 2006 | 05:52 PM
r0tor's Avatar
i still can't comprehend how people are having issues... my cat with the stock exhaust has a couple inches of clearance from everything
maybe there are manufacturing tolerances with a flange angle thats sloppy -shrug-
Old Apr 19, 2006 | 06:09 PM
Dro's Avatar
Dro
Perhaps, either way, the good people over at RP are really nice to deal with and Im sure if there was an issue they would work with you to solve it. He said on all the cars they have installed or tested it on, there was never an issue, but either way an add on hanger was developed and will be available soon.
Old Apr 19, 2006 | 07:08 PM
zaglo6204's Avatar
mine's better
hooray
Old Apr 19, 2006 | 07:09 PM
Mazda-Rati's Avatar
The RB unit is actually 8 or so lbs. heavier that stock. maybe that's enough to make the banging happen.
Old Apr 19, 2006 | 07:11 PM
Moostafa29's Avatar
Storm Trooper
It definitely rattles for some people. I think it may depend on the exhaust though, cause I had no problems, but I helped someone else install one, and it rattled like crazy.
Old Apr 19, 2006 | 07:59 PM
Dro's Avatar
Dro
Hmmmm I have the mazdaspeed dual can ... any idea how this compares to the others in weight ?
Old Apr 19, 2006 | 09:47 PM
galleychief's Avatar
Unbalanced & Unmedicated
See this thread for more info on the RP midpipe
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/rotary-performance-super-cat-midpipe-54033/
ASH8
General Automotive
2029
Apr 10, 2026 02:06 PM
gwailo
May 14, 2024 06:57 AM
Austin22
Sep 23, 2015 04:46 PM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
