Where can i get ADR M-sports?
Old Apr 18, 2006 | 08:28 PM
Mad_8's Avatar
Where can i get them? I want to get a set of 18" and what to knwo if 8.5" front and 9.5" rear is most commonly use?
Will the rim hit the fender (without changing the height)?
Also can i use the OEM tire and wheel Lug or i need to get a new set?
Please advise. Thank you
Old Apr 18, 2006 | 09:58 PM
mahuna's Avatar
http://www.darksidemotoring.com/
THEY MAY NOT HAVE THEM ON THE SITE BUT CALL THEM..........THEY HAD THEM THERE LAST TIME I WAS IN THERE. AND THEY`RE VERY HELPFULL AND HAVE NO PROBLEM TAKING THE TIME TO ANSWER ANY OF YOUR QUESTIONS
Old Apr 18, 2006 | 11:38 PM
Moostafa29's Avatar
Storm Trooper
Check on ebay. They probably have them there.
Old Apr 18, 2006 | 11:52 PM
http://www.1010tires.com/wheelsearch.asp?brand=ADR
http://www.wheelsandtires.com/w_mfg_...8497&BRAND=ADR
http://www.need4speedmotors.com/inde...ATS&Category=4
here is a start..
Old Apr 19, 2006 | 11:07 AM
Mad_8's Avatar
Thank you for all promptly reply!
What is the offset if i want to get 8.5 (i guess i need some spacer in the rear)
Again, thank you guys~
Old Apr 19, 2006 | 12:10 PM
IZoomZoomI's Avatar
Boost needed
38mm works good for both front and rear if you're staying 8.5 all around.
Old Apr 19, 2006 | 10:35 PM
rgonza's Avatar
Rob gonzalez
Hi, Mad 8 i have this rims installed on my car but with 19" height and this fit like a factory ones and yes you can uses wheel lugs and the pressure sensors too.
Regards
Rgonza
Old Apr 20, 2006 | 12:28 AM
http://www.1010tires.com/WheelOffsetCalculator.asp
you can do the math yourself... the stock wheels are 18x8 50mm offset.
chuuuma
12
Nov 17, 2006 03:08 AM
PIGBAIT
15
Jul 26, 2006 06:51 PM
LiL BenNy
Jan 10, 2005 01:32 AM
ROTRYPWR
Dec 13, 2004 01:25 AM
Reximus Maximus
Jul 3, 2004 03:28 AM
