Audio Link Problems - anyone else
Old Apr 18, 2006 | 12:03 AM
Sponge Bob's Avatar
I installed an Audio Link for my iPod a few months ago. It's works OK. Occasionally I have a recurring problem: I turn on the head unit and lose the CD and EX modes. The solution is to turn everything off, unplug the cable that runs from the Audio Link box to the iPod at the Audio Link box. Sart it all back up, and it jiggy again...for while.
This is all well an good, but the wiring harness is less than robust and I think it will eventually fail from all the plugging and unplugging.
ANyone else having this problem?
Bob
Old Jun 15, 2006 | 10:42 AM
Rootski's Avatar
DGAF
I lost the CD mode with my Audio Link unit. Am I supposed to?
Old Jun 20, 2006 | 09:06 PM
wallywld's Avatar
The RPM people I bought my Audio Link from have been very helpful and replaced the first unit which had a bad plug and then that one because of a firmware issue.
I recommend that if you have a problem you should give them a call because they can probably help you right away.
Old Jun 24, 2006 | 12:14 PM
yellowRX's Avatar
Piston? What's a piston
I'm haveing the same prblem right now, and I have the Ipod Nano. My problem tho is I can't get the CD and EX option to come back. Anyone else that has fixed this problem please we need help.
Old Jun 24, 2006 | 01:02 PM
Ajax's Avatar
I had this problem with my PIE adapter when I first got it. The problem was that the cable was not fully inserted into the back of the HU. It felt like it was in place but it wasn't all the way down. Those cables when new are very tight and the pins may not want to go in the first time. Some jiggling and forcing and I got it in place and I haven't had a problem since.
Old Jun 24, 2006 | 01:38 PM
yellowRX's Avatar
I still get power to the Ipod, so dose that still mean I might just have a loose connection.
Old Jun 27, 2006 | 08:38 AM
jenkins-crew's Avatar
check the connector as well to make sure any individual pins didn't get pushed out.
Randolph Alvarez
May 30, 2016 01:08 AM
airlive
Sep 7, 2015 08:32 PM
PortedRotorTuner
NE RX-8 Forum
Sep 7, 2015 01:06 AM
superROB23
Sep 4, 2015 01:22 AM
