REVi and A/C on = Idling issues?
Old Apr 17, 2006 | 11:49 AM
RA-Eight's Avatar
Scuderia
This happened very sporadically the other day. I had my A/C on for the first time ever since I installed the REVi + ram air duct. Sitting at a light, the RPM suddenly crashed <800 RPMs, bounced back up and down again. Naturally, I feathered the gas to keep it up so that the car doesn't stall. I got home and checked for any loose wires/plugs, everything was okay. Tried to test it again, and idle was as rough as before the REVi install. Anyone with a similar experience?
Old Apr 17, 2006 | 12:02 PM
I've had not issues with my AC since installing my Revi. Sorry to hear your AC is acting up...
Old Apr 17, 2006 | 12:09 PM
try clearing the computer memory, the procedure is in the Tech area stickies if you aren't already aware how to do it
Old Apr 17, 2006 | 03:10 PM
RA-Eight's Avatar
Scuderia
I did reset the PCM at the end of the install (both reset procedures).
Old Apr 17, 2006 | 08:31 PM
how's your battery? The car won't idle well with a weak battery ... but then it probably won't crank either, guess I'm just guessing at this point since nobody else has this problem
Old Apr 17, 2006 | 09:12 PM
willhave8's Avatar
FWIW -- I also have the REVi and Ram Air Duct. My car in general idles smoother with them but does every once in a while, it will sputter at idle and then catch itself. Doesn't do it regularly but enough that it doesn't really surprise me. It has never stalled and I have never been concerned with it. I have run the A\C using the defroster and that doesn't seem to be a factor in the idle.
I am not an expert but perhaps you should check your MAF. take it out, clean it, reinstall it...
Old Apr 17, 2006 | 09:55 PM
RA-Eight's Avatar
Scuderia
Battery's brand new, replaced with a new starter under warranty.
Sounds very similar to me. I will check the MAF, when I clean the filter this weekend. I hope it's not serious.
Old Apr 18, 2006 | 03:44 AM
Tigster's Avatar
RX8 ADDICTED!!!
Mine will dip down everyonce in awhile but not too frequent like you describe. I dont worry about it.
Old Apr 18, 2006 | 11:38 AM
RA-Eight's Avatar
Scuderia
I do hope it's an isolated case or else it will be a very long summer for me. :/
Old Apr 18, 2006 | 02:01 PM
Tigster's Avatar
RX8 ADDICTED!!!
I dont think it actually would have stalled, if it did you have something going on other than the intake. To really narrow it doen first clean the MAF, if that doesnt help try putting the stock airbox in and see if it goes away.
Old Apr 18, 2006 | 02:10 PM
Look at the plug, the red cap you installed. Also check for an air leak.
I'm sure you'll find something along these lines as someone else complained and after they examined their install the cap was missing/cracked.
Old Apr 18, 2006 | 02:41 PM
RA-Eight's Avatar
Scuderia
The cap was the first place I checked. It's in good shape, fits nice and snug. I even bought extras from autozone in case it got lost or damaged in transit. I haven't had the need to turn on the A/C so I haven't had any idling issues since.
Old Apr 18, 2006 | 02:52 PM
Tigster's Avatar
RX8 ADDICTED!!!
are all your clamps tight? Also did you look inside the intake to make sure there is nothing in the actual box? Some people found some packing material in the box between the box and the filter.
Old Jun 15, 2006 | 12:02 PM
RA-Eight's Avatar
Scuderia
I'm glad to update that I no longer have this issue. Now quite sure what caused the problem, however I cleaned the box, and clean/recharged the filter. With the filter out, I was able to seal the Ram air duct to the RB air box with Duct Tape. The first time I used duct tape the way it's was meant to be used.
Old Jun 15, 2006 | 12:12 PM
you used duct tape on the box? This I gotta see.... got any pics?
OH, almost forgot: GLAD to hear you got the AC problem worked out.
Old Jun 15, 2006 | 12:43 PM
I have the same issues .... if you want to call it an issue.
Rough Idle when AC is on, but Im not using Revi , Im using RB duct + K&N 2nd Gen.
it never stall but you can tell that the RPM drops when your AC is on.
Let me seal the Duct to Intake part and see if it helps.
Old Jun 15, 2006 | 12:45 PM
Rasputin's Avatar
I found the idle with A/C on already below acceptable levels even with the OEM airbox.
F
Old Jun 15, 2006 | 09:47 PM
RA-Eight's Avatar
Scuderia
Yes, sir I did. The duct tape is inside the box and ram air duct, so you can't see it.
Old Jun 16, 2006 | 07:14 AM
scremn8's Avatar
the more things change
with any car when you turn on the a/c your rpm's will drop. it just depends on how big the engine is. the bigger the engine the less you will notice the drop. by the way i have revi also and no problem's with huge rpm drop..
Old Jun 16, 2006 | 08:23 AM
Rasputin's Avatar
Not true. And it should not happen on the RX8 either if the strategy was properly calibrated. A large spark advance increase should instantly compensate the increase in torque demand. Then an increase of idle air flow (by TPS increase) should take over (it's slower to react). Instead of that, it dips and it rattles like hell. Not good enough.
Fabrice
MikeTyson8MyKids
Nov 12, 2022 11:54 AM
ladnarf1
Apr 29, 2021 11:53 PM
8is>enuff
Sep 24, 2015 08:57 AM
PotatoCannon
Sep 6, 2015 11:48 AM
8is>enuff
NE For Sale/Wanted
Sep 3, 2015 07:57 PM
