High pitched whistling sound from ?engine
Old Apr 16, 2006 | 10:59 PM
blk8's Avatar
BLK8
Hi all. I have a PI 6MT 8 2003. For the past year, the car frequently develops a high pitched whistling sound when the engine is on. It seems to come from the engine compartment, but is louder when the stereo is turned on. Pitch increases as revs increase. Anyone has any idea on this? I've gone through our threads, but there is no mention of this problem. Couldit be a problem with grounding?
Old Apr 16, 2006 | 11:12 PM
yiksing's Avatar
the giant tastetickles
Possibly, it happens in my daily driver. Maybe weak battery or alternator? Anyone?
Old Apr 16, 2006 | 11:34 PM
airspeed's Avatar
Velocity REight
Pitch increases as revs increase, high pitched whistling sound, from the engine compartment... All I can think of are the beltings.
Old Apr 17, 2006 | 12:01 AM
Emperor's Avatar
aka Spectre
Electromagnectic interference, some thing in intake, something obstructing the belts, etc
Old Apr 17, 2006 | 12:19 AM
ngkenny's Avatar
stock standard
did you upgrade your audio stuff? If so, check your stereo wirings (interference)....this kind of 'aeroplane' sound is pretty common.
Old Apr 17, 2006 | 01:53 AM
CoupeM's Avatar
Night Rider
supercharger?
Old Apr 17, 2006 | 02:01 AM
sgrenesis's Avatar
THE GREAT WHITE
Maybe can just tell yourself its the rotary high pitched rev.
Dam! been tryin to get the rotary sound but to no avail.
Old Apr 17, 2006 | 03:52 AM
lohsk's Avatar
"Beng Your Ride"
could you record it so we can have a listen...
Old Apr 17, 2006 | 06:50 AM
SomeGuy_sg's Avatar
Mm...I might be your pulley system on the front of the engine.
Start the car, and open the hood. Listen for the noise. If it from your front pulley system , it would be very easy to identify.
If it is your pulley system, you got 2 way to fix it. WD40 your belt contact points and/or your tensioners. Or change your belts. The belts on the car , any car, will some times dry out . Causing that rubber on metal/rubber screeching .
I hope that is the problem and nothing more serious..
..hehe.. On the other hand the whine could be on an aftermarket supercharger system too :P *wink*wink*
Old Apr 17, 2006 | 08:44 AM
alcimedes's Avatar
The burninator
My money is on electrical interference. Esp. since it gets worse when the radio is turned up. That wouldn't have any effect on belts I can think of.
Old Apr 17, 2006 | 11:27 PM
blk8's Avatar
BLK8
Thanks guys! I've spoken to my audio technician and he thinks it might be a grounding issue. I'll be taking my baby in for a check up soon. Will update you all.
Old Apr 18, 2006 | 07:47 AM
SomeGuy_sg's Avatar
Grounding problem ? Mm...if that is the case, why is the noise coming from the engine ? It ( the interference) should be coming out from your speakers. Does your backlight on your dash sometimes dim or has like an intermitten fluttering ?
vapor2
Nov 3, 2020 03:38 PM
PlayInMyWoods
Aug 8, 2015 07:03 AM
dbarber
Jul 25, 2015 01:34 PM
ironj221
Jul 16, 2015 10:16 PM
AussieGray
Jul 16, 2015 03:58 AM
