Bumper gap?
Old Apr 16, 2006 | 12:30 AM
ndtechie09's Avatar
I'm Burnin for You
Bumper gap?
ok so i took off my bumper last week to do some mods. now when i put it back on it seems as if there is a bigger gap than there was before, is this normal? below is a picture
Old Apr 16, 2006 | 12:32 AM
NgoRX8's Avatar
looks bigger.
looks like the side clips are sticking out too next to the clear corner. We should see that.
Old Apr 16, 2006 | 12:33 AM
FABRO's Avatar
Registered Ricer
yup looks like theres a little gap, did you snap it in place first with the wheel well before you put the bolts back on.
Old Apr 16, 2006 | 12:36 AM
ndtechie09's Avatar
I'm Burnin for You
I'll take more pictures tomorrow and post them. As far as the wheel well, well I forget lol Should I pull the wheel well off before attaching?
Old Apr 16, 2006 | 08:52 AM
jstkilntim's Avatar
resU deretsigeR
The gap does look a little larger, however, I think that the 8's have a "slighlty larger than normal" gap anyway.
Old Apr 16, 2006 | 10:25 AM
chrism's Avatar
Misfit Moderator TnC
i have taken my bumper off a few times and always have the same small gap
Old Apr 16, 2006 | 11:20 AM
NgoRX8's Avatar
Yea, i had a small gap even with my aftermarket front. It wasn't until I hit a tire on the road did it get bigger.
Old Apr 16, 2006 | 05:38 PM
ndtechie09's Avatar
I'm Burnin for You
I think I found the issue. On the passenger side, the clips near the corners look like they are not in all the way.
Attached Thumbnails Bumper gap?-img_6543.jpg   Bumper gap?-img_6544.jpg   Bumper gap?-img_6545.jpg
Old Apr 16, 2006 | 07:17 PM
jstkilntim's Avatar
resU deretsigeR
NgoRX8 & FABRO called it!!
Old Apr 17, 2006 | 12:27 PM
ndtechie09's Avatar
I'm Burnin for You
I haven't attempted to fix it yet. It's on my list of things to do this weekend.
Old Apr 18, 2006 | 11:34 AM
RA-Eight's Avatar
Scuderia
I have the same gap on my passenger side, but the hoodline gap seems normal. I tried to wedge it over the white clips but it seems impossible. I'd advise you tape up the lower portion of your headlights to avoid any scratching. Good luck and let us know if you've fixed it.
Old Apr 20, 2006 | 08:06 AM
ZUMZUM_RX8's Avatar
Speeder
I have the RX-8 front bra on my car due to all the interstate driving I do, I have noticed over time that the gap seems to get a little bigger..... I didn't know if it was the bra that did it or if its just something that happens over time.....
Old Apr 26, 2006 | 10:14 PM
DOMINION's Avatar
I don't buy Kool-Aid
I have a gap from my hood a front bumper.
Old Apr 28, 2006 | 11:24 AM
EZZY's Avatar
cry me a river...
see the attached pic...
the bumper bar goes over those 2 clips things on the guards (circled in yellow).
that will eliminate the gaps.
Old Apr 29, 2006 | 04:49 AM
EZZY's Avatar
cry me a river...
i think i know what you are saying.
"clip" the top lip of the bumper bar into those yellow circled clips before secure the side indicators with the bolt into the guard.
its not hard, they are either clueless or lazy and thinking.... meh... he wont know the difference....
Old Jun 27, 2006 | 02:07 PM
Lensman's Avatar
_________________
Hello from England (its been a while since I posted on this forum: nice to be back).
Oddly enough I noticed the very same problem described above on my car today. I'm fairly sure it wasn't there yesterday so I must presume that the clips have released of their own accord. Another owner in the UK has the same issue so I'm starting to think this is a generic fault. The attached image shows my car (driver's side of course because I'm RHD).
Old Jun 27, 2006 | 02:16 PM
NgoRX8's Avatar
rub in the rhd why don't you? haha, just kidding
im pretty sure if you take off your bumper you'll know how the clips are attached. easy fix.
Old Jun 27, 2006 | 02:41 PM
Lensman's Avatar
_________________
Hey if I was LHD my clock would be on the correct side and my driver footwell would be HUGE!!! You lucky LHDers
Well I've taken the advice of this thread (and a related bumper removal thread) and reset the clip by loosening the indicator light and pulling the whole section away before pushing it home again. It's still gappy compared to the other side but much less noticeable than in my image above. Thanks for the advice and I guess I'll be asking my dealer for a new clip.
Old Jun 27, 2006 | 04:02 PM
Lensman's Avatar
_________________
I don't think this is so: the side of my car with a perfect gap clearly has these two 'tabs' between the two sides of the gap (bumper and lower hood - I needed a Maglite to see them though through the tiny gap). They appear to be, somewhat ironically, spacers designed to stop the once powerful clip from closing the gap too far. I tried putting them under the edge of the bumper and not only is it impossible to achieve both but even with one in place (which is possible) the main catches of the clip can't locate. They're spacers, for sure.
Old Jun 27, 2006 | 04:07 PM
MazdaManiac's Avatar
If you run into things with the lower corners of your bumper, these "clips" will come undone.
Usually, just putting your hand underneath them in the wheel well and pulling up until they "click" will fix it.
Also, the 4 10mm bolts that hold the bumper cover to the upeer fram member have elliptical holes so that you can adjust the hood to bumper gap.
Just pull the white body clips (after you remove the air diverter) and adjust as needed.
Old Jun 27, 2006 | 04:11 PM
zoom44's Avatar
sorry for the hijack but
hello lensman happy to see you around
Old Jun 27, 2006 | 05:47 PM
Lensman's Avatar
_________________
Hey Zoom44, how's things old friend? Those fascinating pre-order days of 4 years ago seem a lifetime ago don't they? I still keep the faith!
(You have 10,992 posts!!! - amazing. )
Old Aug 25, 2006 | 06:39 AM
Apostle's Avatar
Cupcake Master
Actually, the clips have nothing to do with it.
They should be between the bumper and the body. so where they are is fine.
When you put the bumper on, the clip that holds it on the side (under the marker light) is oval. push bumper to desired location and tighten down. no more gap
same thing for the hood. loosen the screws holding bumper on (under Vfad cover) push as close as possible (not oval holes) and tighten.
all gaps will disapear
THREE posts up, basically what he said. didnt see that when i posted
Jst4fun
Apr 17, 2021 07:43 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Digitz0070
Oct 7, 2015 12:43 PM
