Mazmart The leader in late model Mazda parts
WTB New MAF
Old Apr 14, 2006 | 08:48 AM
09Factor's Avatar
Original Turbo 'd Auto !!
WTB New MAF
What is the cost for a "new" Maf. Well least one that isn't broken like mine.
Old Apr 14, 2006 | 10:47 AM
Schuistheman's Avatar
Is a difference between broken and dirty. It can be cleaned but if you touch the maf wires in the process it's toast.
Old Apr 14, 2006 | 11:54 AM
two rotors's Avatar
It is the same MAF sensor as some Protege models.You should be able to buy new for about $75.
Old Apr 14, 2006 | 02:31 PM
mikeb's Avatar
100% Italian
how do you know if your MAF is broken?
Old Apr 14, 2006 | 09:49 PM
09Factor's Avatar
Thanks. Didn't know that.
It also looks close to some of the '02 Wrx Maf.
I would say it's broken because when the engine was swapped the numb nuts the swapped it (read stealership) stripped the screw holes out of the intake and the plastic "shield" around the bulb was missing and the bulb and wire are bent.
So yes I think its broken.
Old Apr 25, 2006 | 02:17 AM
09Factor's Avatar
Paul?
Have any?
Old Apr 25, 2006 | 08:16 AM
Mazmart's Avatar
Originally Posted by 09Factor
Paul?
Have any?
I do, I do. Current used price is $75 (New is $136.19). Give me a call or PM me and I may see if I feel a discount breeze flow my way.
Paul 1 800 221 5156.
Old Apr 25, 2006 | 09:04 AM
Brice-RX8's Avatar
What would be a suggestion if the screw holes are almost stripped out on the plastic tube for the MAF? I have taken it out a couple times to clean it, and that plastic is not very strong and I think the screws have about stripped it out. Would you just use loctite on the screws? Any suggestions.
Old Apr 25, 2006 | 09:47 AM
Mazmart's Avatar
I take it you are referring to the Intake box itself?
Paul.
Old Apr 25, 2006 | 12:54 PM
Brice-RX8's Avatar
Yes the tube the MAF screws into, any suggestions? Just use some loctite?
Old Apr 25, 2006 | 01:43 PM
Mazmart's Avatar
If the threads are 'screwed' up I'm not sure that loctite is the best solution. I would attempt to 'chase' the threads to see if they will revive a bit, then maybe some removable loctite.
Paul.
Old Apr 25, 2006 | 02:16 PM
Brice-RX8's Avatar
Ok, thanks.
Old Apr 25, 2006 | 02:35 PM
XRX8X's Avatar
more then a Mazda
QUICK FIX!!use a larger screw with fine threads half inch long.if you use self tapping and be sure you blow out the excess plastic shavings...works like new!!
Old Apr 25, 2006 | 02:43 PM
XRX8X's Avatar
more then a Mazda
i had this problem when i was making mods to the intake and found out the maf was loose
so i got two slightly larger screws and rethreaded the holes blew out the excess plastic dirt
reinstalled the maf with no more problems...also some time in the future i believe that if someone of the great brains would come up with a maf that would change the air flow measures to let the fuel rate be tuned for better mpg..(don't flame me)
Old Apr 26, 2006 | 08:55 AM
Brice-RX8's Avatar
Thanks again guys, thought about that but didn't know if it would mess something up.
Old Apr 26, 2006 | 02:17 PM
Mazmart's Avatar
Best of luck with that fix.
Paul.
Old May 3, 2006 | 01:22 PM
09Factor's Avatar
Well I finially got the new MAF. Paid for 3day but UPS turned that into a week. Got it yesterday.
Very nice clean MAF Paul.
and it did clear up my knocking issues..
Old May 3, 2006 | 06:43 PM
Mazmart's Avatar
Very Cool. Call me tomorrow if you can so we can clear up your shipping issues.
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
poacherinthezoo
Aug 3, 2016 11:01 PM
Evan Gray
Nov 24, 2015 01:00 AM
Evan Gray
Sep 26, 2015 12:30 PM
