where to run power wire
Old Apr 12, 2006 | 05:30 PM
gotrotary's Avatar
Lightbulb where to run power wire
Hey i was just wondering how people got threw the firewall to the battery on there rx-8's for the power wire. Running 4gauge and was just wondering if you need to drill or if there's a grommet of some sort or something else. I used to be a car audio installer but im to lazy to look myself and figured someone may know. Thanks for the help!!!!
Old Apr 12, 2006 | 05:49 PM
StealthTL's Avatar
Metatron
Wink Heater....
Go thru the rubber the heater hoses occupy, between the washer bottle and the intake manifold. Might be tight for a 4 gauge, but will fit.
(...and yes, for an installer, that IS pretty lazy! )
S
Old Apr 12, 2006 | 05:58 PM
gotrotary's Avatar
thank you very much i went out and looked after i posted lol. but i just wanted to see other opinions. Thats why im not an Installer Any more, im a lazy car salesmen!
Old Apr 12, 2006 | 06:33 PM
AdamK's Avatar
Or, you could do this:
http://koczarski.com/RX8/Mods/HAM/HAM.htm
Old Apr 13, 2006 | 12:47 PM
forbidden's Avatar
Or you can run up to two 0 guage lines through the firewall when you remove the windshield washer resevoir. This is where the JDM version of this cars steering wheel would normally go through the firewall, lots of room there.
Old Apr 13, 2006 | 02:39 PM
gotrotary's Avatar
nice that seems to be the right spot and the easiest espically with where the battery is thanks for all the awesome help!
Old Jun 23, 2007 | 05:10 PM
JMaN06's Avatar
when i remove the windsheild washer resivour i dont see any holes behind there? do i have to make the hole? of am i just missing it? after i remove the 2 bolts at the top, am i supposed to pull the whole thing out or will it just be there?
Old Jun 26, 2007 | 07:55 PM
jstkilntim's Avatar
resU deretsigeR
Pull the whole thing out. You will have to drill the hole yourself. Do not drill too deep.
Old Jul 29, 2007 | 01:43 AM
u1cracka's Avatar
How deep can you drill with out hitting anything like wire's
would using a Step up drill bit work good.
Has anyone used a bi-metal hole saw drill bit.
U1cracka
Old Jul 29, 2007 | 07:22 PM
jstkilntim's Avatar
resU deretsigeR
To be honest, I measured, but forgot the depth. I used a Blue-Point hole cutter, but I think you should be fine w/ a uni-bit. Just drill the first hole and measure before you go bigger. If the uni-bit is too deep, which I don't think it is, you can always dremmel the hole. It seems like there is insullation behind there too.
Old Jul 29, 2007 | 11:41 PM
u1cracka's Avatar
Thanks for the reply I just got done installing my 0Gauge power wire.
There was about 3inch's of space. I used a bi-metal drill bit it worked fine was going to buy a step up bit but they wanted $50.00 and I was afraid it would go to deep.
U1cracka
Old Jul 30, 2007 | 08:19 PM
Crazy Rx-8 Driver's Avatar
XYELLR8
how far did you drill into the firewall?
Old Jul 30, 2007 | 09:48 PM
jstkilntim's Avatar
resU deretsigeR
All the way through!!! (Sorry, couldn't resist.)
Old Jul 31, 2007 | 02:51 AM
u1cracka's Avatar
The firewall is very thin I drilled a small pilot hole and then i used a 7/8 bi metal drill bit. You don't want to push on the drill much so when you drill true it doesn't ram forward when it go's true the firewall.
I then Used a razor blade to cut true the rubber mat that was behind it.
U1cracka
Audio Concepts ATL
Sep 26, 2021 01:59 PM
uZu
Dec 30, 2015 12:35 PM
CMRine04
Jul 29, 2015 02:07 PM
stickmantijuana
Jul 19, 2015 10:33 AM
