18x8.5 with a 38 offset
Old Apr 11, 2006 | 09:57 PM
iammemares's Avatar
Found a set of wheels I can live with for OK money.. They are Konigs from discount and will accept the pressure sensor.
The Discount computer is saying the with 8.5 wide, need to maintain 42 or more offset to avoid tire rub.
I know that a bunch of you are running 18x9s or 19x9s or wider with a 35-40 offset.
So whats the reall deal, is an 18x8.5 with a 38 offset and a 245/40R18 goona rub front or back with stocj height suspension??
Response appreciated as I would like to order the wheels on Wed. Tomorrow.
tried to insert pic of the wheel. hope it works. Thank you very much
[IMG]www.konigwheels.com/catalog_product_details.cfm?CategoryID=1&ss_id=419[/IMG]
Old Apr 11, 2006 | 10:00 PM
iammemares's Avatar
Man,
Sorry for the really bad spelling in that one. Guess I was typing a little to quickly.
How do I get a picture to show up?? And what about that 38 offset?
Old Apr 12, 2006 | 12:02 AM
BigOLundh's Avatar
#1 Legend
Discount tire told me both set of wheels i bought would not fit. Both fit fine.
You should be ok with +35. I am running 19X9.5 + 40 on the rear.. and it fits fine.
-hS
Old Apr 12, 2006 | 01:28 AM
MrWigggles's Avatar
iammemares,
I have 245/40-18's on 18X8.5 that have a 45mm offset. If mine are 45mm and the ones you want to get are 38mm, that difference is 7mm. 7mm is a little over a quarter of an inch.
I can comfortably say that there is at least quarter of an inch of clearance between the outside of the tire and the fender currently on my vehicle in the front wheel wells. I would give yourself a 95% or better chance of those wheels fitting without issues and it should look very very nice with the tire going almost all the way out to the fender.
In the back you will have even more clearance to work with. (In the back have 275/35-18's on 18X9.5 with a 42 offset )
-Mr. Wigggles
Old Apr 12, 2006 | 02:02 AM
Revolver's Avatar
Shootin' from the hip
I am running 18x8.5 with 38 offset (Enkei RP03's) and 235/40R18 rubber (Michelin PS2's) and I haven't had any rubbing problems.
Before you buy 245's, consider 235's. I'm not sure about the availability and cost comparison in the US but I reckon the slightly lesser width sharpens turn in and reduces tyre squirm (a little like the 225's on the stock rim). I appreciate others may have a different view and prefer the widest rubber they can get away with but let's face it, the chassis is hardly overwhelmed with power and I believe it's important to try and keep the sharpness that Mazda's engineers dialled into the car.
Old Apr 12, 2006 | 03:31 AM
RX4life's Avatar
will fit easily..
Old Apr 12, 2006 | 09:16 AM
MrWigggles's Avatar
The problem with the 235/40 is the sidewall is shorter and the diameter is smaller (if there is a perceptable difference in squirm, that would be the cause.)
This means it will ride a little harsher and will add another 1% or so error to the speedo (The RX-8 already reads at least 2 MPH high at 60MPH. With the 235/40 it will be 3 MPH)
The differences between the 235/40 and 245/40 tires are going to be small, but those are the differences.
-Mr. Wigggles
Old Apr 12, 2006 | 09:52 AM
iammemares's Avatar
Thank you for the feedback.
I also appreciate the thought on the 235s. I also believe a 235 would do well. The tires I want to run is the M/L Pilot Sport Cup. This is only available in a 235/35. This would be seriously short, about 6 MM overall. And I agree with you assesment that a 235 is probably enough tire and a good balance for an otherwise stock RX.
The focus on performance is why I am staying with an 18 and not going with monster tires that just increase rolling resistance and unsprung mass.
Looks like I am gonna give the 38 offset a go.
Old Apr 12, 2006 | 07:57 PM
Revolver's Avatar
-Mr. Wigggles
Agree with all that Mr Wiggles. Not trying to oversell the 235 option - just something I prefer.
The speedo error I can live with. If anything, it builds a little more safety margin in when you're being careful NOT to speed (e.g. school zones, etc).
As for ride, I've actually found the ride improved. However, that may be due to the ride difference between the OEM Bridgestones and the Michelin PS2's I've fitted rather than any diameter change. Can't say enough about them - great tyre (oops, sorry - tire ).
Old Apr 12, 2006 | 09:47 PM
09Factor's Avatar
Original Turbo 'd Auto !!
Nice looking rims, but ouch 30 Lbs!
I thought my Falkens were heavy at 23
Old Apr 12, 2006 | 10:12 PM
Revolver's Avatar
Agreed - the OEM's are 20lbs from memory.
Why add 50% weight for looks?? Personal choice I guess.
Old Apr 13, 2006 | 12:14 AM
rotorhead335's Avatar
Revolver:
Very intelligent response. Thanks.
Jeffrey
Old Apr 13, 2006 | 12:53 AM
oem
24 lbs.
Old Apr 13, 2006 | 12:54 AM
http://www.1010tires.com/WheelOffsetCalculator.asp
this is a BIG help..
Old Apr 13, 2006 | 12:59 AM
Revolver's Avatar
Originally Posted by swoope
oem
24 lbs.
Ahh, yes - that's right.
Sorry, we're on metric and my memory of the imperial measurements can be hazy.
Old Apr 13, 2006 | 01:00 AM
Revolver's Avatar
Originally Posted by jeffreyteuber
Revolver:
Jeffrey
No sweat Jeffrey - glad it made sense to someone!
hufflepuff
May 30, 2016 10:45 AM
Kahl
Aug 20, 2015 11:49 PM
Richard Paul
Aug 17, 2015 01:49 PM
R2D2X8
Aug 17, 2015 08:47 AM
