Radar/Laser Detector Install Help
Old Apr 8, 2006 | 07:48 PM
galleychief's Avatar
Unbalanced & Unmedicated
Electrically & Electronically challenged here. . .
I am installing a Whistler 3500 detector. It is a remote unit and the control which will be mounted in the face plate beneath the CD player, has a split power cord, one line is a ground, the other has a fuse in line and a spade type plug at the end. Instructions say to plug the power (spade) into an unswitched 12+ DC slot in the fuse box.
Obviously this spade won't plug into the fuse box. Do I need to get a tap and plug the spade into it?
Is there another wire I can tap into closer to the radio console so I don't have to stretch the wire all the way across?
Thanks for any assistance in advance!!
GC
Old Apr 8, 2006 | 08:41 PM
StealthTL's Avatar
Metatron
Question Unswitched?
Why would you want unswitched power? That's how detectors cause flat batteries.....
S
Old Apr 8, 2006 | 08:58 PM
zenmoused's Avatar
the stig is my hero
You should just get an "add a fuse" from an auto parts store near you. It costs like $3 and allows you to easily tap your accessory fuse. If you wanted to get daring you could tap the power that goes to the stereo/climate control, and that would shut off with the ignition like your stereo. However, it's probably a bad idea, just to save yourself the trouble of laying another two feet of copper cabling, IMHO.
Old Apr 9, 2006 | 08:50 PM
pikachu's Avatar
You can tap into the cigarette lighter. It worked well for me.
Old Apr 10, 2006 | 11:02 AM
Thanks, got it from the cigar lighter.
StealthTL, My bad! It was switched power. I'm apparently "Reading instructions" challenged as well. . .
Old Apr 10, 2006 | 01:08 PM
NomadicRiley's Avatar
How do you like the 3500? Any pics of the install?
Old Apr 10, 2006 | 02:13 PM
So far, so good. Out this morning for a couple errands it detected three different hits, KA and X so I feel comfortable it is working as it should. The worst part of the install was feeding the wire connections through the rear of the CD head unit. Thank goodness for my flexible metal finger tool to allow me to grab the wires and pull them through. And thanks as well to Pikachu for the cigar lighter power connection.
Attached Thumbnails Radar/Laser Detector Install Help-whistler1.jpg   Radar/Laser Detector Install Help-whistler3.jpg   Radar/Laser Detector Install Help-whistler2.jpg
Old Apr 10, 2006 | 04:18 PM
pikachu's Avatar
Looks like a nice clean install. Glad I could help.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
