GOOD NEWS....4 me
Old Apr 6, 2006 | 08:18 PM
OfficerFarva's Avatar
GOOD NEWS....4 me
I just wanted to tell sum1 bc I'm excited, so I figured why not tell the other rx8 people on the forum right?? Anyway, they started my car today and everything seems to be ok. Idle is at about 800, and its holding about 15 inches of vaccum. But, when they revved it up, it still was giving problems past about 3/4 throttle. There gonna try and do sum tuning in the next little bit to straighten it out. I'm thinking that the 2ndary injectors are just flooding it w/ gas when the throttle is more than 3/4. I'm curious, do the 2ndary injectors come in at 7500 or so regardless of how much throttle is givin or only under heavier throttle? Thanks.
Old Apr 6, 2006 | 09:57 PM
hondasr4kids's Avatar
I believe secondarie Injectors come on at 3750 RPM, but not sure.
Old Apr 6, 2006 | 10:15 PM
MadDog's Avatar
Consiglieri
Check out my thread called something like "better fuel management using the emanage". I posted logs of the injector duty cycles versus RPM.
Old Apr 7, 2006 | 02:09 PM
Aseras's Avatar
secondary injectors are on at 3750, secondary intake ports open at 3750 as well. tertiary ( 3rd set on manuals only ) injectors open at 7500.
Old Apr 9, 2006 | 04:17 PM
thanks for the thread maddog (once again ur there for every1). I'm supposed to head down tomorrow and maybe pick up the car. They drove it day before yesterday and straightened out the bucking problem. They said they put it in 3rd and at 1500 rpms gave it full throttle and the turbo spooled instantly and accelerated with no lurching or bucking and held 5.5 psi throughout, which makes me feel good to know that the E-manage is working properly. But, there is oil getting into the BOV, and we think it's the return line b/c it's kinked at about 90 degrees and backing it up. Anyhow, there gonna replace the return line and hopefully that fixes it. If not, it could be a prob w/ the turbo, but since the turbo has hardly been used i seriously doubt that's the problem. I'll let yall know what happens tomorrow, peace.
Old Apr 9, 2006 | 08:39 PM
yiksing's Avatar
the giant tastetickles
Oil catch tank might help with the oil in BOV?
Old Apr 10, 2006 | 01:41 AM
I have an oil catch can i sent them, but maybe they forgot to install it. But, i'll find out after i wake up and get down there.
Old Apr 10, 2006 | 11:45 PM
So everything looks great, but they haven't finished installing the wideband yet and were still wondering about the gauge mounts. But, that's about all there is and soon it will be mine .
Old Apr 11, 2006 | 04:31 PM
lourx8's Avatar
Early RX8 Adopter
Did you finally go with low compression rotors?
Old Apr 11, 2006 | 05:55 PM
I have custom fit 3mm seals. They won't lower the engines compression necissarily but they are stronger seals and can take more boost comfortably. Hopefully they'll increase the longevity of the motor with the turbo. But I found out today that they mounted the boost gauge next to the steering column and the afr gauge is for now temporarily in the glove box mounted with sum velcro but I'll figure out a permanant set up for that later. I'm trying to get back down there tomorrow b/c they told me they need to finish the wideband installation tomorrow morning and check the AFR and then it will be ready.
TJSiegrist
Sep 10, 2015 09:29 AM
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
iTs Ghastly
Aug 28, 2015 02:40 AM
