Ground Loop Isolator
Old Apr 4, 2006 | 02:47 PM
marvin_rock's Avatar
L8 BLOOMER
So I searched and searched and searched. And no one ever mentions how to install it. I would like to know the pros/cons with the ground loop isolator and what not. Here's my setup. I've got all the fancy audio stuff (see signature for details) and I'm using the Auxmod basic with a Creative Zen mp3 player. I finally broke down and bought the car charger for it because it finally became available. Well, needless to say if I plug it AND the auxmod headphone jack I hear the alternator whine and all that jazz. I want to be able to plug both in at the same time. Now a lot of people I've heard say the the GLI from Radio Shack reduces sound quality pretty bad. So is that the only thing that I could use? or is there something else to elimanate engine noise. Also, if it IS my only option, how do I install it? Thanks in advance.
Old Apr 5, 2006 | 01:37 AM
no the gli does not change anything but the noise...
and yes i have everything you have and more..
Old Apr 5, 2006 | 08:03 AM
L8 BLOOMER
So how do you install it?
Old Apr 5, 2006 | 01:31 PM
wallywld's Avatar
I also have the RadioShack GLI installed and have not had a perceivable change in the quailty of the music. I've had it installed in my Chevy truck for a long time.
Basically I installed it between my carputer and the input to the amps.
(If it's the same one I have, the one with RCA's on both ends and a largish round object in the middle)
Old Apr 5, 2006 | 10:39 PM
get it,
follow directions on back of package. you will need to buy rca to 3.5mm adaptors.
Old Apr 7, 2006 | 10:44 AM
L8 BLOOMER
Got it all, did it in the parking lot of radio shack, sounds wonderful. Just to run it by you and compare, here's the set up
Auxmod - Y- Adapter - GLI - Female RCA/Headphone jack - mp3 player - charger
Everything seems to be going fine. I just wondered if I should have a plain headphone cable in the loop somewhere. I saw it as excess so I didn't use it. Thanks for the help, I was worried I was going to have to splice some wires to get it to work.
Old Apr 8, 2006 | 02:10 AM
aint it cool!!!!
Old Apr 11, 2006 | 11:23 PM
L8 BLOOMER
How did I miss your response. Thanks. I appreciate all the help. BUt hey, lookie, there's a DIY on the GLI. Enjoy.
Old Apr 11, 2006 | 11:28 PM
did you do one??? i havent seen a gli diy...
glad it worked.
Old Apr 12, 2006 | 02:14 PM
forbidden's Avatar
Guys, think about this a little more. If the gli is removing the noise from the audio stream, it is also removing the exact same frequencies of music from the audio stream. The "whine" that you hear has a frequency range, the gli is removing that entire frequency range.
Old Apr 12, 2006 | 06:22 PM
L8 BLOOMER
I see your point, but I havn't noticed any difference in my music whatsoever. I don't really know how it works to be honest and Swoope would be the man to answer that one. I think it has more to do with the current of electricity vs. the signal pitch.
Old Apr 12, 2006 | 10:56 PM
magic to me. i just read fix and spew forth the knowledge that i can retain. probably not a lot.
the freq ?? is an interesting one. i dont think it is a problem..
Old Apr 13, 2006 | 12:43 PM
forbidden's Avatar
You may not have noticed at all for this reason. The minute you plugged your unit in and used it, the noise was there. So you may not have ever heard what it was meant to sound like in the first place. Next as the whine is the more predominant sound that you are hearing, it masks the less powerful sound that is your music. Too bad we could not make one of these devices for the women in our lives....
Old Apr 15, 2006 | 08:16 AM
L8 BLOOMER
HA!
Anyway, I actually had mine in there for almost two weeks before I hooked up the GLI. And like I said no real difference. If I had the volume turned up enough on the stereo I wouldn't really hear the whine unless I took my engine to about 7500. After installing it, there's no background noise, and like I said, everything seems to be the same. But I'm DEFINATLY no expert on this topic, just relaying my experiences.
OnebaddRx8
Aug 25, 2019 11:34 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Rote8
Sep 22, 2015 03:43 PM
iwannarun
Sep 6, 2015 01:37 PM
