blown engine
Old Apr 3, 2006 | 06:39 PM
joon's Avatar
strictly rotory
Angry blown engine
well ive been quiet for a while now but after getting a custom built turbo installed, the tech blew the engine while tuning with the interceptor-x. the air fuel ratio was at 18.
Old Apr 3, 2006 | 06:41 PM
FABRO's Avatar
Registered Ricer
sorry to hear about the misfortuanes, if you don't mind me asking what kind of setup did you have for your custom turbo?
Old Apr 3, 2006 | 06:45 PM
joon's Avatar
strictly rotory
it was a t4 garret turbo, custom fabricated exhaust manifold, tial 44mm wastegate,tial bov, with interceptor-x
Old Apr 3, 2006 | 06:46 PM
joon's Avatar
strictly rotory
also cat deletion with racing beat exhaust system
Old Apr 3, 2006 | 06:59 PM
W1CK3Dninja's Avatar
i would atleast have him take all the custom parts out and install the oem stuff. that's the least he can do. then atleast the dealer can replace the engine under warranty.
Old Apr 3, 2006 | 07:03 PM
joon's Avatar
strictly rotory
its to late for that, i had the car towed to the dealer for a compression test because the car did start even though it took awhile to get her going only to find out from the dealer that the compression test was so low that it wouldn't register
Old Apr 3, 2006 | 07:09 PM
joon's Avatar
strictly rotory
i know now one rotor and one housing has to get replaced
Old Apr 3, 2006 | 07:29 PM
Moostafa29's Avatar
Storm Trooper
If they are tuning your car with a AFR of 18, maybe you should take it elsewhere.
Old Apr 3, 2006 | 08:44 PM
ddub's Avatar
always preoccupied.
Yep, sounds like inexperienced tuners....
Old Apr 3, 2006 | 09:09 PM
BigOLundh's Avatar
#1 Legend
yeah, how did it get to 18 AFR?
Old Apr 3, 2006 | 09:15 PM
grapes's Avatar
Very sorry to hear about your misfortune. Sounds like the project was going well.
Old Apr 3, 2006 | 09:24 PM
mysql101's Avatar
how the hell did they get it to 18? Did they do that on purpose? Who's footing the bill?
Stock, your car will cut the fuel completely if your AFR is too lean. I guess the interceptor-x bypasses that protection.
Old Apr 3, 2006 | 09:28 PM
Moostafa29's Avatar
Storm Trooper
They seriously had to have altered the fuel quite a bit, because it comes pretty rich from Scott, as a safety measure.
Old Apr 3, 2006 | 09:36 PM
BigOLundh's Avatar
#1 Legend
Eventhough the original poster will probably provide the actual explanation.... im guessing there must have been a failure with the fuel delivery system. Like no fuel.
-hS
Old Apr 4, 2006 | 12:09 AM
rkostolni's Avatar
We need the full story. We have many interested people here. How many pulls had he done? What AFR did you start with? Why was he so lean? What boost were you running? How long was the Interceptor on your car for before tuning?
Old Apr 4, 2006 | 10:30 AM
Red Devil's Avatar
Wow...18...they must not know what they are doing, or couldn't figure out how to use the Interceptor...yes, more details would be appreciated...
Old Apr 4, 2006 | 10:32 AM
joon's Avatar
strictly rotory
first off all i would like to say that i bought the interceptor-x because i heard a lot of good feedback from members that bought it and i know that its not the problem at all. first of all the tech at the performance shop here in illinois that installed the turbo and tuned my 8 which i was under the impression he understood everything ran it extremely lean. i paid for an upgraded fuel pump which turns out a month later he did not install. i cant reveal to much because ill be taking this guy to court to settle the damages caused on my car.
Old Apr 4, 2006 | 10:34 AM
joon's Avatar
strictly rotory
the first dyno run produced 174.2 hp and the second dyno produced 161.7hp at both air fuel peaking at 18 i have the dyno sheet to prove.
Old Apr 4, 2006 | 10:37 AM
wwkicker's Avatar
I have a brand new renesisi engine for sale. If anyone is interested, my email is wwkicker @yahoo.com.
Old Apr 4, 2006 | 10:46 AM
joon's Avatar
strictly rotory
i had my car shipped to mazsport scott for engine rebuild and where he will properly tune the car with his interceptor-x. will let you know how the progress goes
Old Apr 4, 2006 | 10:55 AM
Animagix's Avatar
tuner sounded like a douche
Old Apr 4, 2006 | 11:08 AM
Nemesis8's Avatar
Bigus Rotus
Post some pics once Scott cracks it open - would be curious to see the guts.
Old Apr 4, 2006 | 11:09 AM
PUR NRG's Avatar
Definitely sounds like your tuner didn't know what to do. After one run at 18 AFR he should not have taken a second without drastically changing the settings.
Here's what most tuners will do:
1. Run a baseline pull to see what the car does with boost controller turned off.
2. Verify/adjust for proper AFR/timing with boost controller turned off.
3. Increase boost by ~2psi and repeat Step 2.
4. Continue until target boost level is met.
________
INFANT DEPAKOTE
Old Apr 4, 2006 | 11:22 AM
Red Devil's Avatar
Joon, would be really cool if you brought out your 8 to one of our Chicago meets once Scott gets it up and running...good luck with the car and please keep us posted...
Old Apr 4, 2006 | 04:34 PM
joon's Avatar
strictly rotory
red devil sure once i get my 8 back hopefully by the end of this month. what area in chicago are you from?
