Suspension bottoming out
Old Apr 3, 2006 | 04:02 PM
edj's Avatar
edj
RX8 Steering Wheel Spacer
[not sure where to put this but since it happens while autocrossing this seems
like the best place]
I recently switched from the RB front swaybar to a softer bar and now on
grippier surfaces I'm getting "klunks" from the front suspension on high G
turns. Asher's car apparently is also doing this (he has the OEM bar). This
never happened with the big bar.
Does anybody know what is hitting? Is it the shocks (Koni yellows) bottoming
out or something else? Is anybody else having this problem?
I'm guessing the "fix" is a stiffer bar and/or more bump.
thanks,
edj
Old Apr 3, 2006 | 04:21 PM
I never had this problem and plenty of people are running an even softer bar including OE and OE shocks (softer bump than Koni shocks) without the issue
You do have the bumpstops installed on the shocks, right?
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
No klunk on my car. I drove mp5's car and his has a klunk. On his car I think the end links are hitting the shocks, he has a stock front bar but has moved the endlinks up to make it stiffer.
Check the shock body for any marks.
Does your bar have stops on the swaybar so it can't move side to side? Some bars that don't have the stops can move side to side and cause a bind and klunk.
Old Apr 3, 2006 | 04:30 PM
edj's Avatar
edj
The bump stops are on the shocks. I checked the fronts to see if I could find where it
is hitting but I didn't see anything. I'll be checking again this week.
Old Apr 3, 2006 | 04:38 PM
mp5's Avatar
mp5
Speaking of sway bar stops, is it normal to have about 1cm of slack between it and the bushing? Noticed this last night. Also, the right shock is missing some paint near the endlink, but I was too lazy at the time to change back to the stock hole.
Old Apr 3, 2006 | 04:44 PM
whiterex's Avatar
Pink Means PASS
I seem to be having the same issue... I thought that it was the bar binding from a lack of grease. Only happens on fast/hard turns.
Old Apr 3, 2006 | 05:18 PM
ULLLOSE's Avatar
The bar stops should not ride on the bushings, it should have some movement. With your track record I bet your klunk is just another loose nut.
Old Apr 3, 2006 | 05:50 PM
I never ran any grease on mine
Old Apr 3, 2006 | 07:37 PM
mp5's Avatar
mp5
It'd be cool to stick a chase cam in your wheel well during a run to see what's actually hitting.
duworm
Oct 1, 2015 04:57 PM
Rote8
Sep 22, 2015 03:43 PM
To The Wonder
NE For Sale/Wanted
Sep 12, 2015 12:35 PM
