What's with the ground wire to the stock muffler?
Old Mar 31, 2006 | 08:01 AM
NoCones's Avatar
You down with 13B?
I put this on last night:
http://www.racingbeat.com/resultset....rtNumber=16396
The ground wire isn't long enough to reach the new cannister, so for now it's kinda rigged to the long hanger coming off of the cannister...just wondering how much trouble I should go to to get it to the new muffler. What did those of you with custom setups do?
Old Mar 31, 2006 | 08:22 AM
John V's Avatar
Not ******
I don't recall re-connecting the ground wire. But it has been a while since we upgraded to the Borla.
Old Mar 31, 2006 | 09:17 AM
MazdaManiac's Avatar
It helps maintain a uniform ground across the whole chassis.
This, in turn, reduces the stress on the alternator (which, in turn, reduces the load on the motor) and suppresses odd PCM behaviour, ignition issues and radio interference.
Old Apr 1, 2006 | 12:37 PM
the afterburners won't kick in properly without a good ground ...
I left mine loose, the only way to connect it to my custom would have been to extend it or run a new one
Old Apr 1, 2006 | 12:45 PM
expo1's Avatar
He's as bad as Can
The Greddy SP2 doesn't have a mounting point for the ground strap, this is how I rigged mine.
https://www.rx8club.com/showpost.php...&postcount=106
Old Apr 4, 2006 | 12:32 AM
McCalll's Avatar
so it basically doesn't do anything I'm tempting fate by not running mine anymore
Old Apr 4, 2006 | 10:53 AM
And by that logic, neither does your spleen.
Old Apr 4, 2006 | 01:16 PM
McCalll's Avatar
Ok, if we try and follow your weak analogy, then someone must have lost an alternator or worse a whole motor by not reconnecting that ground wire. Can you in fact show me some hard data (tech) that proves this thing actually does anything? To me it sounds like you are just spouting an aftermarket grounding kit's marketing line. Amazingly enough, my car starts, runs fine, and the radio works great.
Do you sell grounding kits? What's with the kool-aid drinking?
Old Apr 4, 2006 | 01:26 PM
Brice-RX8's Avatar
The thing is why would there be a grounding strap back there if it wasn't needed for whatever reason? It obviously has some sort of function. What that function is I don't know for sure, but my guess would be something to do with the O2 sensors.
Old Apr 4, 2006 | 02:48 PM
Asher's Avatar
I've got the same exhuast and didn't reconnect the ground. I've put about 5k miles on it with no noticable problems.
Old Apr 4, 2006 | 10:04 PM
Well, I suppose your reading comprehension leaves something to be desired, so I'll first implore you to re-read my original post and compare it to you logic above.
No one will loose a motor or an alternator. The stress isn't nearly enough for that.
But what you will have is a non-uniform ground that will rob you of performance. How much is up to you.
There are english and reading classes at a local community college near you, no doubt.
Old Apr 5, 2006 | 10:52 AM
McCalll's Avatar
not worth the time it took to write. Please drive through...
Old Apr 6, 2006 | 12:40 AM
it could potentially cause an issue with the O2 sensors if you had a bad ground somewhere else, in general though it's not much to be concerned with. The OE exhaust gaskets are all metallic, so you'd essentially have to lose your grounding between the battery and the engine to have a problem ... and this would likely cause bigger issues
Old Aug 5, 2018 | 06:07 PM
jsanderbeck's Avatar
Grounds
The more clean grounds the better.The engineers would not spend a dime without a need.Nothing like responding to a 12 yo post-lol zoom
Old Aug 28, 2018 | 06:36 AM
hufflepuff's Avatar
Perhaps it plays a role with corrosion?
Old Sep 2, 2018 | 07:17 PM
Clamp it to the hanger with a SS C clamp
WikkedOne
Oct 25, 2008 02:41 AM
laythor
Jul 22, 2007 03:28 AM
rkostolni
Oct 26, 2004 03:56 PM
robertdot
Jun 15, 2004 11:46 AM
