Is it a good idea to run 3" midpipe on NA?
Old Mar 30, 2006 | 01:28 AM
r.c.y.k.'s Avatar
as topic stated, and i am not planning to change the catback anytime soon.
Old Mar 30, 2006 | 01:37 AM
Fanman's Avatar
I don't believe there is a big point to it. The exhaust will just pressurize at the cat back mufflers. If you go 3", then you have to get freer flowing cat back exhaust.
Old Mar 30, 2006 | 12:34 PM
r.c.y.k.'s Avatar
but would there be any downside compare to 2.5" midpipe with stock catback?
Old Mar 30, 2006 | 01:23 PM
Fanman's Avatar
Not really. Won't be a downside.
Old Mar 30, 2006 | 03:42 PM
FLybOi drE's Avatar
i do believe that the bigger piping you go with on a NA, you will get more HP gain on the high end but lose low end torque which our cars lack.
Old Mar 30, 2006 | 04:34 PM
Moostafa29's Avatar
Storm Trooper
Only thing it will hurt is your ears, and those of people around you.
Old Mar 30, 2006 | 10:11 PM
r.c.y.k.'s Avatar
so if i run 3" midpipe with res with oem exhaust i would lose some low end torque? also with res it shouldn't be much louder than stock right?
Old Mar 30, 2006 | 10:41 PM
Fanman's Avatar
Not seeing it. How would he lose low end torque ? Most midpipe/hi flow cat installs I have seen give hp pretty much across the board or at least fatten mid range, if little hp on the top end.
If you have a resonator it will still be loud, as the cat. acted as a second resonator, but less then a straight testpipe. I had a hi-flow cat w/resonator & it was a little louder. Now I have a hi-flow cat w/o resonator & it is really quite a bit louder. I have heard one with midpipe & Corksport exhaust & thought my ears were going to bleed.
Old Mar 31, 2006 | 12:14 AM
r.c.y.k.'s Avatar
so Fanman, in your opinion, u would say there is no performance diff from 2.5" and 3" with stock catback?
Old Mar 31, 2006 | 03:42 AM
i will help some if i can... if you dont open it up all the way to the back, difference is going to be close to nill....
Old Mar 31, 2006 | 12:24 PM
Fanman's Avatar
Yep, little to no difference. 2.5" is plenty for a stock engine. Unless you open it up behind it no point.
9krpmrx8
Nov 5, 2015 11:45 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
yapakanichi
16
Jul 28, 2015 03:44 PM
MolecularConcept
Jul 26, 2015 09:09 PM
