So when i approach 99mph the car starts to vibrate really bad, ideas?
Old Mar 25, 2006 | 10:46 PM
toxin440's Avatar
Exclamation So when i approach 99mph the car starts to vibrate really bad, ideas?
Okay -- i recently took my baby to discount tire in fort worth to get my tires rotated and blanced. (Avon Tech M550s) And I finally got to go on a 200 mile road trip to see my family back home and on the road between fort worth and houston i got to "stretch the legs" of my car and was shocked that when I get to 99+ my car starts to vibrate very badly.
There is no noticable vibration at low speeds (thats why i havent noticed it for the past two weeks, city driving i stay below 45 all the time. Also keep in mind that BEFORE i had this rotation and balancing, the car didnt do this at ALL, I.E. i could take it far beyond 99mph and it was smooth as butter.
So to summarize when i hit REALLY high speeds, i get massive vibration. I havent hit any curbs/bumps/etc and the fact this started after having a rotation/balance done tells me its something to do with the tires and not any suspension stuff.
I'm going to call discount tire and try to make them look at it in a few days but in the meantime I would lov to get some input from you guys (and gals)
Jeff
Old Mar 25, 2006 | 10:56 PM
Easy_E1's Avatar
sound's like you need to have the tires balanced AGAIN.
Unless they left some lug nuts loose.
Old Mar 25, 2006 | 10:59 PM
Mugatu's Avatar
Even My Dog Searches
yep. sometimes wheel balancing can be tricky and bit of a pain. get it done again by a different shop.
^^ Good advice....check your lug nuts.....then get them re-balanced.
Check the tires as well...might have a defective tire ...although it should be a problem at all speeds if it's got a bump in it
Old Mar 25, 2006 | 11:50 PM
toxin440's Avatar
thanks for the input guys!
Ive never had any problem like this and it struck me as odd that I would only notice this at really high speeds.
Old Mar 26, 2006 | 12:06 AM
saturn's Avatar
i pwn therefore i am
I think it's clear that at 100mph your car will open up a wormhole to Narnia.
Old Mar 26, 2006 | 12:45 AM
mazdabob's Avatar
One time, I had my wheels balanced, and shortly thereafter the car started shaking. I went back, and we discovered that all the weights were gone. Turns out the guy that did it was new, and he used the wrong weights (wrong curvature).
Old Mar 26, 2006 | 10:10 PM
toxin440's Avatar
weights? can you elaborate?
Old Mar 26, 2006 | 11:14 PM
They use lead weights to balance the wheel assembly. They are usually either stick on squares...or weights that attach to the edge of the rim beads with a little clip.
Both types can fall off if not installed properly
Old Mar 27, 2006 | 11:04 AM
Transam kid 01's Avatar
The anti-ricer
Jeff
Was it balanced or high speed balanced?
Old Mar 27, 2006 | 11:05 AM
guy321's Avatar
Humpin legs and takin nam
Don't drive at 99mph?
Old Mar 27, 2006 | 01:33 PM
bulletproof21's Avatar
When I hit 88 mph in my car one time I ended up back in the 60's. Had to harness the energy from a lightening strike to get "back to the future".
Old Mar 27, 2006 | 06:37 PM
stickman's Avatar
If they did a static balance instead of spin balance that could be the problem. Also could have used wrong weights or they didn't put one on securely and you threw it off while driving. It is also possible that you have an alignment problem that caused uneven tire wear and when the tires were rotated it became noticeable at high speed. In the extreme, they could have tightened the lug nuts in a very uneven manner and warped the rotor but if that was the case you should feel when you brake.
Old Mar 27, 2006 | 06:42 PM
lawsorp_rx8's Avatar
Taking the Long Way Home
Where did you get your Flux Capacitor at? I've been looking all over for one.
Old Mar 27, 2006 | 06:55 PM
stickman's Avatar
I found you can use a hampster on steroids instead of a flux capacitor. The little guy can get 12000 rpm in brief bursts.
Old Mar 27, 2006 | 07:00 PM
Rich Rx-8's Avatar
I notice my car sways a little on the highway when i've only driven a short distance, then stays perfectly straight after a little more time of the tires heating up.
Old Mar 27, 2006 | 07:01 PM
On a more serious note, I called Auto Zone one time as a joke and I asked the guy if he had a Flux Capacitor for a 1985 Deloreon in stock. All I got in response was silence..........................
Old Mar 27, 2006 | 07:03 PM
Mugatu's Avatar
your attempt at a joke backfired on you. in keeping with the movie, you would have gone to 1955, silly.
but of course, you MEANT the 60s, now didn't you.
Old Mar 28, 2006 | 01:07 PM
I wouldnt say it backfired on me, but yes you are correct about 1955. Good call.
tbiggybig
Aug 13, 2016 06:30 PM
rotorocks
47
May 11, 2016 03:23 PM
9krpmrx8
Nov 5, 2015 11:45 PM
madrotor
Jul 26, 2015 12:06 PM
thedragonrotar
Jul 22, 2015 08:46 PM
