Which ones are the control arms?
Old Mar 25, 2006 | 10:05 PM
Captain Amazing's Avatar
I love cars but do not really know anything about them.
Attached Thumbnails Which ones are the control arms?-axle-001.jpg   Which ones are the control arms?-axle-002.jpg   Which ones are the control arms?-axle-003.jpg   Which ones are the control arms?-axle-004.jpg
Old Mar 26, 2006 | 08:39 AM
alnielsen's Avatar
Control Arms connect the wheel spindle to the cars chassie and control the up/down movement of the wheel. On the 8 you have 2, an upper and lower control arms. In the last picture, you can see a bolt with an ecentric washer. Turning this bolt will align the suspention. The bar in the front of the last picture, is a control bar to keep the rear end from moving sideways.
Old Mar 26, 2006 | 12:50 PM
Krankor's Avatar
Klingon Grammarian
Alright, I completely don't get it. I thought going over a rock controls the up/down movement of the wheel. Are you telling me there's something in the car that makes the wheel go up and down??
Old Mar 26, 2006 | 03:35 PM
stickman's Avatar
Krankor, no, the control arms just hold the wheel in position. The rx8 it has what is called a double wishbone set up in the front end. Think of two wishbones held flat, one above the other with the pointy ends on the same side for both; the pointy end of the top one is connected to the top of the wheel spindle, the pointy end of the bottom one is connected to the bottom of the wheel spindle. The large open ends of both are connected to the frame of the car. This allows the wheel to move up and down when it hits a bump, when you steer, the wheel pivots on the spindle.
Old Mar 26, 2006 | 08:57 PM
demob05's Avatar
Correct if I'm wrong, but in a Double Wishbone suspension, isn't there a Lower control arm w/ a sealed Ball Joint, and a Strut type setup in lieu of an upper control arm??
Old Mar 27, 2006 | 03:46 AM
Krankor's Avatar
Klingon Grammarian
Ok, that makes sense. So it doesn't really control anything, it just lets the wheels go up and down as need be, yes? As opposed to being mounted on a fixed, unmoving part of the frame?
Old Mar 27, 2006 | 05:04 AM
rotarenvy's Avatar
why would double be in the name then? two wish bones (A arms) = double
struts are when the shock is used as one of the physical suspension links (not just something to resist it's motion).
Old Mar 27, 2006 | 06:05 AM
DOMINION's Avatar
I don't buy Kool-Aid
Is there a "Popcorn" smilie?
Old Mar 27, 2006 | 06:32 PM
stickman's Avatar
Yep, just lets the wheel move up and down. In the front end the shock connects to lower control arm assembly.
Old Mar 28, 2006 | 02:04 AM
Krankor's Avatar
Klingon Grammarian
Ok, thanks!
pjwermuth
Sep 28, 2015 11:36 PM
titaneum_grey
Sep 16, 2015 11:51 PM
yankeepicker
Sep 11, 2015 05:42 PM
