Replaced gas cap 4+ weeks ago and CEL is still on
Old Mar 24, 2006 | 11:10 PM
Captain Amazing's Avatar
I had a faulty gas cap which caused a CEL. The dealership gave me a new one 4 weeks ago and told me that it will take a few starts for the CEL to go away. Is it normal for it to take more then 4 weeks for the CEL to go away?
Old Mar 24, 2006 | 11:14 PM
I give it 4 clicks after a fill up each time. Is that enough?
Old Mar 24, 2006 | 11:37 PM
Raptor2k's Avatar
Club Marbles Member
CEL should of been gone when they gave it back to you. Not normal.
Old Mar 24, 2006 | 11:38 PM
BunnyGirl's Avatar
I thought they reset it for you?
Old Mar 24, 2006 | 11:42 PM
I brought it in and they told me they need a new cap but did not have one in stock. They then told me they would call me when they got the part. When I left the dealer that day the CEL was gone because of the tinkering they did. When I went back to let the dealer install the new cap my CEL came on after I started the car again at home with the new cap.
Old Mar 24, 2006 | 11:45 PM
BunnyGirl's Avatar
That's strange. I think there might be something else going on with your car.
Old Mar 25, 2006 | 12:29 AM
Hornet's Avatar
Wut da F Y'all lookin' @!
I've had the CEL come on twice since I've had the car and both times it was the gas cap. Oh yeah, they also pointed out they noticed I turned the traction control off on the last visit for this problem. During this most recent time that I took it in I asked them what I could do to avoid this from occuring in the future and they told me "after you turn it and get a few clicks turn it back as if you were taking it back off then tighten it again". I don't really know if it works but I haven't had a CEL since I've been doing this so I can only assume this helps with the problem!
Old Mar 25, 2006 | 08:41 AM
Go48's Avatar
If the gas cap was, in fact, the problem the CEL should have self-cleared by now--assuming you have gone through a bunch of off-on cycles during that period. So take it back and have them try again. The problem may be another component of the evaporative control system, or something else all together. If you have access to a CANbus-OBDII scanner, you can read the error codes yourself to determine the cause of the CEL. Try AutoZone or buy a scanner if you want to do it yourself.
Old Mar 25, 2006 | 12:59 PM
Aseras's Avatar
Do the brake stomp KAM clear and see if it comes back.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
ei8ht
Aug 21, 2017 09:08 AM
vetteor8
Aug 9, 2015 05:56 PM
whitelight42
Aug 6, 2015 01:10 AM
