HCTR154
03-22-2006, 05:25 PM
I am going to purchase a lighter flywheel soon. Probably the ACT streetlight from Rotary Performance in Garland.
I am in the Woodlands/Conroe are and would like to know if there are any reliable shops around that will not try to rip me off when I go to get an install.
Also, what else should be replaced while doing this? Is it necessary to replace the clutch, plate and throwout bearing?
Thanks.
buzzardsluck
03-22-2006, 09:29 PM
cant help you on the shops but i would think it would run $200+ in labor(just guessing 3 hour job @ $70 an hour). dropping a tranny just sucks.
i also dont think you need to replace anything, im assuming you have less than 30k. your clutch and pp should last for quite some time. have you tried a search on this subject?
HCTR154
03-22-2006, 11:19 PM
Thanks for the info. I tried a search and I always seem to get to much info to search through, half of which never seems to have anything to do with swapping a flywheel.
rotarygod
03-27-2006, 01:34 PM
Give Curt a call at Tracktime Performance. They are by Willowbrook mall which isn't too far from there. While you're there you can go play with the track cars!
713-907-0345
HCTR154
03-27-2006, 03:27 PM
713-907-0345
Thanks, I will call them.
