Steering problem
Old Mar 17, 2006 | 09:32 PM
Er28's Avatar
Steering problem
Hi just like to check you guy face this problem. Each day when i start my vehicle the steering seem lock and when i start to move it vibrate n become light. But after a while eveything since back to normal, so is there anything with my steering
Old Mar 17, 2006 | 09:40 PM
Tigster's Avatar
RX8 ADDICTED!!!
huh??
Old Mar 17, 2006 | 10:07 PM
lennon's Avatar
Most car have this steering lock function. It's common. but is the vibration come from the engine or you feel it on the steering wheel?? Do you warm up the car before driving it??
Old Mar 18, 2006 | 01:11 AM
RX8_666's Avatar
Hi Er28. Is yr car a PI car? Probably u would want to check with 2F2F. He had this problem too but dont know whether is it solved till now. His is a PI 6 MT.
Old Mar 18, 2006 | 07:08 AM
Er28's Avatar
Yes my is a PI 4A thank, will check wt him
Old Mar 18, 2006 | 09:46 AM
Neon's Avatar
Black Ace
Bro,
I am facing the same problems recently.....Come to think of it ours abt same time rite?
Hmmm......Interesting.
If i find out anything, will post it asap.
Cheers
Old Mar 18, 2006 | 11:54 AM
Daverx's Avatar
tHe mOd-DeR
Originally Posted by Neon
Bro,
Cheers
Bro... seemed to be all having same problem....found out recently to solve the problem..... = $1k plus.....
Old Mar 18, 2006 | 11:55 AM
Daverx's Avatar
tHe mOd-DeR
http://www.souting.com/Download.asp?...JlpouzH1At7zl5
Old Mar 18, 2006 | 06:07 PM
lowrider's Avatar
A wanker with the Wenkel
So, what exactly was the mystery problem that cost 1k?
Old Mar 18, 2006 | 09:02 PM
Er28's Avatar
so what the problem we here to share, what your workshop did that cost 1k to solve the problem, must be seriuos.
Old Mar 19, 2006 | 03:45 AM
Neon's Avatar
Black Ace
Hmm...simi taichi ah Dave?
Old Mar 19, 2006 | 09:32 PM
Daverx's Avatar
tHe mOd-DeR
initially would cost more than 2k.....2F2F had it fixed earlier which was more then 2k. was told the mounting i think & some other mechanical fault eg relay etc....
The cost went down recently n was told about 1k plus...n can be fixed by TG....
same same problem...expecting more.... haha
Old Mar 20, 2006 | 10:15 AM
M-ster's Avatar
maybe can arrange for bulk discount if all were to arrange to go togther.
Old Mar 20, 2006 | 10:34 PM
zavhan's Avatar
Bro I had tis problem b4 and it got worst till power steering was gone !
However I had it fixed for less than $100 ! It all boils dwn to the power steering relay as ours are electric driven ! Replaced the relay at about $45
and labour to identify and repair the electrical points.
The wrong earthing of ur wires also contribute to tis issue bcoz when we start our engine, electrical pulses are suppose to reach the relay to activate power steering, if the relay fail to get the required signal it will stall for a while !
However urs could be more serious issue, dun mind sharing wif me ! I m worried mine would reach ur stage of problem too, PM me can ?
Old Mar 20, 2006 | 11:28 PM
Neon's Avatar
Black Ace
Hmm, i hope mine is the stoopid relay problem. Will post soon whether i paid 100$ or 10 times more!
Thanks Zav Bro!
Old Mar 20, 2006 | 11:34 PM
Emperor's Avatar
aka Spectre
Sometimes it pays not to listen everything at face value. Either you pay $100 or $1000k for similar repairs.
The salesman who sold me my 8 also said the car sale and repair industry is one of the dirtiest.
Old Mar 21, 2006 | 02:29 AM
Daverx's Avatar
tHe mOd-DeR
Yup, it may be the relay problem (we hope so)... so before any replacement do test the relay 1st by replacing an ok one....iif not then too bad liao....
keep our fingers crossed
Old Mar 27, 2006 | 04:19 AM
RENESIS8's Avatar
Wow.... I got this same problem 2 months ago right after I changed my battery. At first, I tough something need to be reset or what.
The problem goes like : When the car's engine is cold, especially in the morning; when you steer the wheel to the right, everything is fine. But when you steer the wheel to the left, it goes jerky & vibrating ...................
I have to make the sterring wheel lock to lock 3 to 4 times, then the problem will go away..................
Hopefully is just a mater of the relay problem..............
Old Mar 27, 2006 | 06:09 AM
Neon's Avatar
Black Ace
Sam, told u to drive the car into singapore river liao lor......
hehe....
Old Mar 27, 2006 | 10:04 PM
RENESIS8's Avatar
Hahaha.......... Your car oor mine........??????????
Old Mar 27, 2006 | 10:42 PM
Daverx's Avatar
tHe mOd-DeR
Yez..all this happened after when your battery is flat or battery changed. So I suspect that something need to be reset too coz why only occured only after battery changed??!!??!!?? puzzled!
Old May 10, 2006 | 11:00 AM
Er28's Avatar
worst
my steering getting worst anyone know where or which workshops can solve this problem.
Old May 11, 2006 | 02:26 AM
RENESIS8's Avatar
Went down to Garge R to install the ENDLESS brake pad & Steel braided hose. Mentioned to Wong about this problem & according to him, Most of the Type S has got this problem. All U have to do is to change the Steeling senosr and reset the
ECU. The whole process takes about 2 to 3 hours and the charges is about S$100 plus.
Old May 14, 2006 | 01:58 PM
snkpkp's Avatar
Have the same problem in my 2003 6MT 8. There is a torque sensor which is built in to the motor. Are you talking about the steering sensor? Someone also mentioned about the relay. where is this relay located? I ordered a power harness as suggested by many, but may be i need to change the relay or sensor. any idea where is the relay?
Old May 16, 2006 | 04:15 PM
snkpkp's Avatar
helloooooooo anyone in Asia solved this problem?????????
