Does the rear view mirror block your vision?
I find the placement of the 8's review mirror perfectly blocks my view of cars coming from the right at an intersection. I have caught myself twice heading into an intersection with a car sitting in the lanes on the right who I never saw. I have to resort to ducking down below the mirror to see if it is safe to go. I think they should have moved the mirror up and inch. Anyone else?
This is the inside mirror, right? The mirror is adjustable. Look at the arm that it is fastened to and you will see a joint in it. Push the mirror up out of the way. This has been covered several time before so a search would have provided this information.
no, but i find that the driver's side side view to be completely blocked by the rear, driver's side cabin chassis and often have to look more than once to the mirror before changing to the left lane.. passenger's side view is fine though.
Even pushed all the way up, I'm completely blocked looking at right-hand apexes and cross-traffic from the right. I'm getting tired of doing the gooney bird thing trying to look around the rear-view. Think I'll mount a second windshield plate above the current one and move the mirror base up that inch and a half.
Had the same problem in the 3rg gen RX-7. The Sparco Evo took care of that problem, though.
And I'm only 6'...
And I'm only 6'...
Hmm, never had a problem with this..
If there was no one in-front of or behind you on the left .5 seconds ago, it should be clear to your left, no?
I have the same problem -- I put the seat all the way down, and back as far as it will go, and I tilt the mirror up as high as it will go, but I still can't see around it to the right. I think they just don't build cars for people who are 6' 2" tall like me :-). My Chrysler minivan has the same problem.
jwitzer, let me know if you do move your mirror up. I'd like to know how it works for you and how hard it was to do. I have the Homelink/auto dimming mirror, so it might be more complicated to move the wiring, but I plan to keep the car for a long time, so it might be worth the trouble.
-- Michael
-- Michael
most people don't know that there are two hindges, so the center rear mirror can move up quite a bit. By default, most will come with it at a very low position. I was getting into near accidents because of it.
Also the rear visibility can also be awkard - this is easily fixed by getting the bubble mirrors installed on your side mirrors. I can glance and immediately see if i'm clear to make a lane change. Just make sure your mirrors are positioned so you don't see much of your side doors, otherwise it's not angled out far enough.
-- Michael
-- Michael
What I'm worried about is the new windshied mount sticking to the "tint".
I think I found a simple and free solution. Can't believe I didn't think about this before.
I rotated my rearview mirror 180 degrees (so it's now "upside down"). I can now move the mirror up until it touches the headliner/wire track and the view is much better.
The only button I use on the mirror is the center HomeLink, so very little behavior modificaiton is needed.
When you turn your mirror, be careful to note which way would untwist rather than twist the wiring.
Of course, I still want the Sparco Evo...
