View Full Version : SCCA Classification Question
BigOLundh
03-17-2006, 12:19 AM
I've been autocrossing for 2 full seasons now, but never with SCCA. Looks like i'll be at an SCCA event next month, so i had a quick question in regards to classification. I'm not trying to compete... i'm just looking to get more seat time in and become better, faster, and more knowledgeable.
I looked it up in the rule book, and I believe i will be in STU... but i'm not sure.
- The car is Turbocharged.
- The Current wheels are 17X9
- Current Tires are 255 Falken RT-615
Is there anything else that I didn't list that could possibly have bumped me into a different class?
Thanks for the help
-hS
TeamRX8
03-17-2006, 01:07 AM
can't add a turbo in STU, it's Street Mod for you!
Silverarrow
03-17-2006, 01:50 AM
yes, but is it sm2 or sm?
TeamRX8
03-17-2006, 02:11 AM
as long as the weight is 2500# or greater and displacement 1.5L or less it's SM
Class SM
Eligible Vehicles:
All sedans/coupes (models which were originally equipped with a
minimum of four seats and four factory seat belts).
Excluded Vehicles:
Porsche, all
Lotus, all
Nissan / Datsun Z car 2+2, (Pre ’90)
Honda CRX
MGB GT
Triumph, all
Displacement Limits and Minimum Weights:
I. Up to 3.0L, naturally aspirated, OHC engines
Up to 4.0L, naturally aspirated, pushrod engines
FWD: 1800 pounds
RWD (front engine): 2200 pounds
AWD and RWD (rear & mid-engine): 2400 pounds
II. Up to 3.0L, forced induction, OHC engines
Up to 4.0L, forced induction, pushrod engines
FWD: 1900 pounds
RWD (front engine): 2400 pounds
AWD and RWD (rear & mid-engine): 2600 pounds
III. 3.01 to 6.0L, naturally aspirated, OHC engines
4.01 to 6.0L, naturally aspirated, pushrod engines
Up to 1.5L, rotary engines, all
FWD: 2000 pounds
RWD (front engine): 2500 pounds
AWD and RWD (rear & mid-engine): 2700 pounds
BigOLundh
03-17-2006, 02:58 AM
can't add a turbo in STU, it's Street Mod for you!Looks like your right... Below is where in SM it gives me the allowance for boost.
16.1 ALLOWED MODIFICATIONS
D. Drivetrain and related components (induction, ignition, fuel
systems, etc.) are unrestricted except for the following limitations:Then it goes on to certain limitations that do not apply to me.
Well, at least its one less letter to cut on the magnet.
-hS
TeamRX8
03-17-2006, 07:43 AM
oh ye of little faith ... :p:
RX-Hawk
03-17-2006, 03:20 PM
It is kinda confusing though, in Appendix A:
Supplemental Class STU
Coupes/Sedans - 4 seats minimum
Engine Displacement
- any normally aspirated or
- up to 3.1L forced induction
(single turbo/supercharger).
Mazda RX-8:
STU
Mitsubishi Lancer Evolution:
STU
Dark8
03-17-2006, 03:34 PM
But nowhere in the rules for stock or stu rules does it say you can add forced induction to your car. If it doesn't specifically say you can, then you can't.
The Mighty Red
03-17-2006, 03:43 PM
The forced induction in STU ( I think ) must be factory. After-market FI moves it out of the class.
I think that's how it works.
TeamRX8
03-17-2006, 10:34 PM
yes, the engine from the throttle body to the exhaust port face must be OE with exception for several stated allowances; A/C removal, etc.
