Bamboozeled
Old Mar 16, 2006 | 01:41 PM
griffe's Avatar
Bamboozeled
Question:
I have been reading my manual in order to find out if I turned the DSC off/on does the light on the dash light up signifying that DSC is off. I tried pressing DSC button, but I don't know if when I press it, am I turning it off or on?
Also I noticed when I decelerate there is humming sound coming from the front passenger wheel. It happens when I apply brakes or even when I don't. Have anyone else has this problem?
Old Mar 16, 2006 | 01:43 PM
saturn's Avatar
i pwn therefore i am
I'm fairly certain based on what people here have said that the DSC (which you can only turn off by holding the button down for a few seconds) turns back on every time you start the car.
My guess for the humming is an alignment issue. Check the tire pressure and all that. If it still happens, take it to a dealer.
Old Mar 16, 2006 | 04:59 PM
Krankor's Avatar
Klingon Grammarian
Yeah, what saturn said. The light on the dash is to warn you that it is off.
Old Mar 16, 2006 | 05:08 PM
abs016's Avatar
"Z88M" is my fast!
start car: DSC is ON and TSC is ON
Press DSC button : dsc is turned off : "dsc light" is ON
press and hold dsc for 7 seconds: tsc is off : "tsc light" is ON
hope this helps.
Old Mar 16, 2006 | 05:09 PM
BlueEyes's Avatar
This is not a case of bamboozlement. How dissapointing.
Old Mar 17, 2006 | 10:18 AM
griffe's Avatar
Unhappy
hope this helps.
Did that. Still didn't help. I noticed when I start the car, the "DSC Off" light is on, but then turns off. Should I hold button while starting car?
Old Mar 17, 2006 | 10:20 AM
snizzle's Avatar
Shakezula, the Mic Rula
those lights never fail to bamboozel
Old Mar 17, 2006 | 10:59 AM
jwitzer's Avatar
Require IQ test to vote!
Press and hold dsc for 7 seconds: tsc is off : "tsc light" is ON
hope this helps.
Press DSC button : toggles DSC mode : DSC light indicates system OFF
You can turn DSC off and on repeatedly.
After turning DSC off, continue to hold DSC button for 7 seconds: TCS is off : TCS light indicates system OFF
Once TCS is off, only ignition OFF/ON will bring either (both) back.
Old Mar 18, 2006 | 12:02 AM
mazdabob's Avatar
When you start the car all warning lights briefly light up as a check.
