wb o2 sensor signals?
Old Mar 14, 2006 | 02:13 PM
Petrus's Avatar
v e i l o c i t y
Hi guys,
I need some signals for my wbO2 unit....
I have located most of the signals/wires but I canīt find the source for the GREEN wire... Can you help me out here?
If you know any of the other wires/colors please feel free to post it (then I know for sure if I did it correct)...
Old Mar 14, 2006 | 02:55 PM
rkostolni's Avatar
Easiest place to tap it is at the ecu. Just look on the wiring diagrams for the rpm wire. If you can't find it I'll look when I get home tonight.
Old Mar 14, 2006 | 03:23 PM
StealthTL's Avatar
Metatron
Wink Green....
The signal wire for the leading plug ignition coil is the green one of the three in the connector. Or you could tap in at the ECU, in the largest of the ECU plugs, it is the only all green wire.
I can't tell you if the signal you get will be good enough for your wideband, nor if tapping into that signal will fry anything,
....but then, that's NMFP.
S
(....not my_____problem.)
Old Mar 14, 2006 | 04:45 PM
rkostolni's Avatar
Since you have the Greddy kit, just tap the rpm wire off of the rpm extractor dongle.
Old Mar 15, 2006 | 02:53 AM
Petrus's Avatar
v e i l o c i t y
Yeah,, Of course I didnīt throw that paper away saying which dongle it is, or what wire. I have 3 dongels so any helt there would be appreciated..
Iīm stating to sound like a pain in the a**...
Old Mar 15, 2006 | 05:35 AM
Petrus's Avatar
v e i l o c i t y
...found it. Thanks for the help guys, I have located all the signals now. Time to put the Zeitronx unit to work.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
XianUnix
Sep 29, 2015 03:48 PM
