Check Engine Light
Old Mar 10, 2006 | 08:03 PM
PerformRX-8's Avatar
ROTARY-A-HOLIC
Exclamation Check Engine Light
As you guys know I'm new here, I own an '05 AT black RX-8 and I don't really know much about the RX-8.... Today I was driving on the NJ Turnpike when all of a sudden the check engine light came on and the AT light came on too... does anyone know what this is, please help me!
Old Mar 10, 2006 | 08:09 PM
G8rboy's Avatar
Mmmmm... Rotary Donut
Don't know what the AT light is, but a common cause for the CEL when your car is running fine is a loose gas cap... usually takes a couple start/stop cycles after a fill-up for the CEL to come on. Besides that, there's not enough info to guess on other causes... you might want to invest in a code scanner if you're going to be doing much modifying.
Old Mar 10, 2006 | 08:13 PM
tiggerlee's Avatar
May Cause Anal Leakage
If all else fails take it to the dealer.
Old Mar 10, 2006 | 10:59 PM
born2drive's Avatar
"AT" means automatic transmission. Something is probably wrong with your tranny and this is most likely the reason the check engine cell is illuminated.
Since both of these cells are on, you may not want to drive it much and get it to a dealership ASAP.
Old Mar 10, 2006 | 11:01 PM
ROTARY-A-HOLIC
well i dont have a choice, this i the only car i have.... the AT light actually went out, but the CEL is still illuminating....
Old Mar 10, 2006 | 11:08 PM
tiggerlee's Avatar
If you don't know the reason for the CEL then take it to the dealer. That's what the warranty is for. If they have to keep it any length of time ask for a loaner car.
Old Mar 11, 2006 | 02:11 AM
BunnyGirl's Avatar
My dealership says it is definitely a "bad sign" if the CEL is flashing. Is your's steady or flashing???
Old Mar 11, 2006 | 04:34 PM
ROTARY-A-HOLIC
steady why?? what does it mean?
Old Mar 11, 2006 | 04:51 PM
BoilerX8's Avatar
Well there is something in your glove box called a manual that you could read to get some ideas on what is going on...
Old Mar 11, 2006 | 04:57 PM
tiggerlee's Avatar
Yep that little book is full of useful information.
Old Mar 11, 2006 | 07:14 PM
born2drive's Avatar
The manual will also tell you what every cell means along. You should spend some time reading the manual. It will tell you a lot about the car you may not know about.
Old Mar 12, 2006 | 04:22 PM
BunnyGirl's Avatar
It means there is a problem but it is less urgent than if it is flashing.
ladnarf1
Apr 29, 2021 11:53 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
