Want to check details on these 19s...
Old Mar 10, 2006 | 06:31 PM
Waz's Avatar
Waz
I am about to buy a set of Blitz Technospeed Z1s in 19s. The fitment they have is 114.3 and 5 stud, with offset of 45. Both the front and backs are 8" wide. Are these okay for the RX-8? Will I need some spacers to line up the wheels with the fender? A recommended tyre size would be appreciated too.
Thanks,
Waz
Old Mar 10, 2006 | 06:33 PM
the outer lip will only be 5mm further out than the OE wheels, assuming the clear the front brake caliper should be fine. Are they specified as an RX8 fitment? The only other thing to be concerned about is the centerhole size. The Mazda hubcentric stub on the hubface is 67.1mm diameter
Old Mar 10, 2006 | 07:21 PM
BigOLundh's Avatar
#1 Legend
just make sure they clear the brakes... other than that you should be fine.
If your buying it online you maybe screwed if they don't fit. Make sure you know who you're buying from.
-hS
Old Mar 11, 2006 | 05:07 AM
Waz's Avatar
Waz
Someone is selling them off a Civic Type R (UK spec), so not sure of they are speciifc RX8 fitment but the PCD matches up...
Old Mar 11, 2006 | 05:29 PM
Waz's Avatar
Waz
Just found the bore on the CTR is 64.1 and the RX-8 is 67.1 Is there no way of getting these to fit then?
Waz
Old Mar 11, 2006 | 05:35 PM
not without a machinist boring it out
Old Mar 12, 2006 | 07:16 AM
Waz's Avatar
Waz
Infact they may fit as the owner has been given rings to make them fit the CTR! Will ring Blitz tommorow and check for sure but anyone have any pics of 19x8" all round with +45 offset> Want to see how it fits in relation to the fenders!
Old Mar 12, 2006 | 09:13 AM
it's 5mm further out, you won't even be able to tell the difference
if the centerbore can be adapted then your main concern needs to be whether or not they will clear the front brake caliper
Old Mar 13, 2006 | 12:24 PM
Waz's Avatar
Waz
Hi guys, thanks for all the help so far! Talked to Blitz and they reckon as the wheel has a smaller center bore than that of the RX-8 and so won't fit on directly. They said some hub-centric wheel spacers would perhaps do the job tho!? Anyone care to elaborate on this? If I do get the wheel spacers, what size should I get to make them line upto the fenders nicely?
Thanks,
Waz
fireishot34
Sep 5, 2015 06:45 PM
