Warning - Let it idle for awhile
Old Mar 6, 2006 | 12:08 PM
dupa12345's Avatar
the de-chocking procedure didnt work either?
Old Mar 6, 2006 | 12:14 PM
abs016's Avatar
"Z88M" is my fast!
Thanks for the heads up. I always fear the same. I park my '8 in the garage.. everytime i deicde to take it out or park it in, i first drive it around the block for 3-5 mins and then drive it in. Now, after your story, I am all the more convinced that i should NEVER doubt this.
Sorry to hear abt ur flooding.
Old Mar 6, 2006 | 12:19 PM
tekk's 8's Avatar
JRZBOY 8
Originally Posted by bjtitan00
Yes, I finally screwed up. I didn't let the car idle after I washed my RX-8. I got busy and just drove it the 12 feet into the garage and turn the engine off. I paid the price. It flooded the engine and the next day I could not start it. There is no way to fix this except tow it in for service. But I was still under my 50,000 warranty and Mazda paid for everything. Dang, I would say I knew better but obviously I didn't believe the dealership. I had the car since 2004 and it finally happened to me - what a dummy I am.
I hope this just serves as a warning to the rest of you smarter guys....
Thanks for the heads-up. Everyone makes mistakes.
Old Mar 6, 2006 | 12:21 PM
khtm's Avatar
I like rusty spoons
There IS A WAY to fix a flooded Renesis.
Look in the DIY forum.
Student Driver
What flash do you have?
Old Mar 6, 2006 | 12:24 PM
NoTears316's Avatar
Shock and Awe
Congrats, you should be getting yourself a new battery and starter.
http://www.finishlineperformance.com...4-05-1448e.pdf
Old Mar 6, 2006 | 12:36 PM
newcastle's Avatar
Carbon Fiber Roof
Hmm perhaps I should shut my engine off cold so I get a new battery and starter!
Old Mar 6, 2006 | 12:38 PM
BunnyGirl's Avatar
Old Mar 6, 2006 | 02:02 PM
BaronVonBigmeat's Avatar
Senor Carnegrande
No, it's Mazda's fault for not installing the new starter and motor from the factory as standard equipment. It makes a huge difference.
Before (even with proper warmup previously):
(turn key) rur rur rur rur rur rur rur rur rur rur (pause...sigh...) rur rur rur rur cough sputter pop stumble (uneven idle)
After:
(turn key) whiiirrrrVROOM!
Old Mar 6, 2006 | 02:05 PM
Tirminyl's Avatar
Listen to Zoom44
Did you not read that he owned the car since 04?
Old Mar 6, 2006 | 05:45 PM
UFGator12's Avatar
TEBOW FOR HE15MAN
I cut mine off cold all the time and crank it back up. It's a 2004, and it cranks fine everytime. Actually, now that I think about it, I kill the engine a lot when it is not warmed up. Pulling into the garage, going across my school's campus, etc. I'm not sure if I have the new starter or not, but everything works fine for me.
Old Mar 6, 2006 | 07:27 PM
Senor Carnegrande
Do you not think that Mazda could have forseen this problem, and designed the proper starting system from day 1?
Old Mar 6, 2006 | 09:05 PM
LBDboater's Avatar
Crazy!
This is crazy... you shouldnt have to drive around in to go park it! If I want to, I should be able to fire it up and let it idle a couple of minutes and shut it right down. I should be able to do anything like that... pull it out to look at the beautiful silver paint for 1 second... get back in and pull it back in the garage and not have to worry about flooding or the need to drive it around the block a couple of minutes!
Old Mar 6, 2006 | 09:12 PM
Red_X8's Avatar
You bought a car without pistons, if that didn't tip you off that this car is completely different from anything else, maybe you bought the wrong thing.
Old Mar 6, 2006 | 09:15 PM
maggotcorpse666's Avatar
RRDI Member
No, not crazy! It's just the nature of the beast. It's a rotary, not a piston POS, different rules apply.
Old Mar 7, 2006 | 01:07 AM
DOMINION's Avatar
I don't buy Kool-Aid
Old Mar 7, 2006 | 08:13 AM
Tirminyl's Avatar
Listen to Zoom44
I apologize on Mazda's behalf. Reading aren't most peoples strong suits.
Old Mar 7, 2006 | 08:26 AM
Shoafb's Avatar
What? Just cause an engine is piston it is POS?
I pull my piston engine car out, wash it pull it back in..... the 8 I have to pull it out, drive it around, wash it, drive it around some more and then pull it back into the garage. Oh, and the piston engine gets better MPG while still have 100+ or so more hp and tourqe over the rotary in the 8.....POS I think not.
Old Mar 7, 2006 | 02:28 PM
Krankor's Avatar
Klingon Grammarian
I will never, ever get people like this. Every single fact that you are complaining about her was public knowledge when you bought the car! Don't you shop for a car? I'm not just talking about Shoafb, there seem to be an awful lot of people who bought 8's and then bitch about them for things that they could have and should have known before they bought the car. If it's not the right car for you, fine, but it's your own damn fault if you bought a car that's not the right car for you. Not Mazda's, not anybody else's.
Old Mar 7, 2006 | 02:35 PM
sojourner's Avatar
Just passing through
One of the things I find most appealing about this car is that it is a driver's car, meaning that a little more time needs to be spent caring after it, but the rewards are more than worth it. I have a '73 914 that requires simple maintenance every time I drive it. Nature of the beast. And I have owned it for better than ten years.
Old Mar 7, 2006 | 04:18 PM
Shoafb's Avatar
Try reading my post before replying next time.
The statement was made that Piston engines = POS. I was merely stating that they clearly are not and as a matter of fact hold some advantages over the rotary. I knew what the deal was before my wife bought the car. I researched it and knew the shortcommings of the Rotary and I could deal with it if that is what she wanted. She doesn't race anyway so power and tourqe is not really an issue.
Old Mar 7, 2006 | 06:28 PM
LBDboater's Avatar
Sorry
Same as all my other posts, I'm sorry. As in one post I clearly stated... I love this car. I just wish it didnt do some things. I dont think when I bought the car that flooding was a possible issue with the car just because its a rotary engine. I'm really sorry for venting on everyones topic.
Old Mar 8, 2006 | 01:42 AM
Krankor's Avatar
Klingon Grammarian
Perhaps. Read your own post again, it still came off as whiny. But I certainly agree, piston engine != POS.
Old Mar 8, 2006 | 07:11 AM
Shoafb's Avatar
Not whining about it, just stating the facts. Piston engines are not POS.
