View Full Version : Illuminated Shifter Knob
Goldenhue22
08-07-2003, 09:02 PM
Does anyone know if the installation of the illuminated shifter knob will be a problem in the US spec 8's. Is it easy to install?
ramfann
08-07-2003, 11:54 PM
where did you find it? i will order one and tell you how it goes
Titanium Grey
08-08-2003, 01:59 AM
They're a standard accessory in the UK so it's one of the must haves for me.
There will have to be some sort of wiring in the gear leaver, take your gear knob off and have a look, there may just be one wire though because it may 'ground' through the metal of the gear leaver itself.
eccles
08-08-2003, 09:11 AM
Originally posted by Titanium Grey
There will have to be some sort of wiring in the gear leaver, take your gear knob off and have a look, there may just be one wire though because it may 'ground' through the metal of the gear leaver itself. Having had the gear shift boot and surround off as part of the MP3 player install, I can tell you that there's no dedicated wiring for the shift knob under there. I suspect the illuminated knob will probably draw its power via a wire tap spliced into the ashtray lighting.
tripwire
08-08-2003, 03:16 PM
I thought I read somewhere that the "Red" glow is always on, created from an "Indiglo" effect. Like on "Indiglo" writs watches. As though it had a button cell battery in it. Could be wrong. I'll try to find where I read that.
Goldenhue22
08-08-2003, 10:42 PM
RAMFANN- Go to JAPANPARTS.COM
They have everything there. They told me that the illuminated knob will work on US spec cars. I just wanted to know if someone has done this yet as they may just a sale.
tripwire
08-08-2003, 11:22 PM
I didn't see it listed in their inventory - did you find it on their website?
The Beav
08-08-2003, 11:28 PM
i'm pretty interesting in seeing how's it illuminated, i don't think i could deal with a wire, but if it's battery powered that'd be cool, or maybe even solar powered, like those glow in teh dark watch hands
eccles
08-09-2003, 12:16 AM
Originally posted by The Beav
i don't think i could deal with a wireYou wouldn't even know the wire was there if it was thin enough to pass between the shift shaft and the shift boot; the wiring would all be hidden under the boot.
ramfann
08-09-2003, 02:36 AM
are you talking about the leather shift knob that has the shift pattern light up?
Jt-Imports
08-09-2003, 05:51 AM
Bro you need to have the wiring. Its kind of a bummer. Some RX7 guys wanted it a while back so I looked into it, and there is a lumination light for the Jspec ones at least.
JT
Puppy1
08-09-2003, 08:16 AM
Originally posted by ramfann
are you talking about the leather shift knob that has the shift pattern light up? Exactly.
