ULLLOSE
03-03-2006, 11:52 AM
It took a few months and a very slow boat from down under, but now we can upgrade to poly swaybar bushings and use our stock hardware:
http://www.dpeweb.com/ProductDetails.aspx?ProductID=1079&vehicleID=58
p.s. these should fit the stock and MazdaSpeed bar. :cool:
GeorgeH
03-03-2006, 01:43 PM
Thnkx, just ordered a set.
TeamRX8
03-03-2006, 04:33 PM
they've been available since before the RX-8 came out, you can order Energy Suspension bushings from almost anywhere for a lot less and they have the grease fittings with new brackets even
didn't think they carried them
TeamRX8
03-03-2006, 04:45 PM
http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?catalogId=10002&storeId=10001&categoryId=13009&parentCategoryId=10059&langId=-1
universal 1-1/16" Part no. 355-9-5162G for black color bushings, replace the "G" with "R" for red, $13.95 for a pair from Jegs linked above
When you go to install them the bracket on the top side will slightly overlay onto a clip that holds the ABS wire, bracket holes are slotted - push them downward as far as you can, when you tighten the nuts down the bracket will pull down and conform properly with a slight overlay on the clip, nothing to be concerned with :)
ULLLOSE
03-04-2006, 01:03 AM
I have a set of the ES ones, did not like the way they fit with the MS bar.
TeamRX8
03-04-2006, 06:23 AM
I don't have a clue why, they're more than adequate :dunno:
