Help! How to read VIN on RX-8?
Old Mar 2, 2006 | 01:36 PM
towergus's Avatar
For example what does JM1FE173640123373 mean?
What is the production number of this car is?
Old Mar 2, 2006 | 01:44 PM
BlueEyes's Avatar
Did you search? I don't know that you'll be able to determine the production number. But the build date is in your door.
Old Mar 2, 2006 | 01:49 PM
expo1's Avatar
He's as bad as Can
Try https://www.fleet.ford.com/maintenan...ls/default.asp
Old Mar 2, 2006 | 01:53 PM
rodrigo67's Avatar
hope this helps...
JM1FE17N*4#123456
J=Japan
M=Mazda
1=Passenger car
FE is the carline series within the VIN for USA
The following digit is the restraint system type "1"
The next digit is the body style. "7"
The next digit is the engine type "N"- std power, "3" High power
The next digit is a check code 0-9, or "X"
The next digit is the model year. "4"-2004
Next digit is assembly plant. "0" Hiroshima, "1" Hofu
The remaining digits are for the numerical serial # of the vehicle.
That's the VIN sequence for North American RX8
Old Mar 2, 2006 | 01:57 PM
ucfracerx8's Avatar
Pistons are Over Rated
It is a 2004 and it is RX8 #23373 ever made, well officially anyway. I think Mazda uses consecutive numbering, so it does not reset to 00001 for 2005. A quick search yielded this:
https://www.rx8club.com/showthread.p...59289#poststop
doh, only 3 of us responded around the same time, must remember to reload faster.
ASH8
20
Sep 26, 2022 11:55 PM
ASH8
Oct 30, 2021 12:50 PM
drebbrnator
Dec 27, 2018 07:02 PM
dafiltafish
Aug 21, 2015 06:56 PM
whitelight42
Jul 22, 2015 04:13 PM
