Oil Drain Plug
Old Mar 1, 2006 | 12:35 PM
jlegendls's Avatar
Oil Drain Plug
Anyone ever use this drain plug?
The LPE designed magnetic drain plug is truly the first no mess, easy to use chip collector. A unique one way check valve keeps oil in the pan while allowing inspection of the chip collector. Also available, the Quick Drain adaptor which snaps into the drain plug and allows easy draining of the pan without unscrewing the plug to eliminate possible spills. SX drain plug kits fit most SBC and BBC applications including L98 & LT1 with non metric 1/2" drain plugs.
Seems like a good product idea....
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
Sifu
Aug 30, 2015 10:51 PM
reni04
Aug 21, 2015 01:33 PM
Obivious
Jul 29, 2015 05:57 PM
