Tire Size ?
Old Feb 24, 2006 | 03:03 PM
blue flash's Avatar
Tire Size ?
I need new tires- 225/45/R18 91W IS AROUND $200@they have 235\40 r18 95w for only $130 @ will this tire be o.k.thanks
Old Feb 24, 2006 | 08:35 PM
zaglo6204's Avatar
mine's better
what tire?!?!?
Old Feb 24, 2006 | 08:39 PM
zaglo6204's Avatar
mine's better
oh yeah, & to answer your question...
the tire will be slightly wider, & a bit smaller radius.....i think its a -2.2% difference in circumference for 235/40, if i recall correctly, so your speedo will be a bit high. other than that, shouldnt be a problem.
Old Feb 28, 2006 | 10:54 AM
blue flash's Avatar
Bmp
Old Feb 28, 2006 | 01:32 PM
NoCones's Avatar
You down with 13B?
Originally Posted by blue flash
Bmp
zaglo basically answered your question...the tire is going to be wider but have a shorter sidewall and smaller circumference, causing some speedometer/odometer accuracy issues. It will look a bit different from stock too. Whether that's "ok" is up to you...it'll fit the wheel fine and function properly.
Play with sizes here:
http://www.miata.net/garage/tirecalc.html
Old Feb 28, 2006 | 02:30 PM
fizzer's Avatar
G-force addict
Do they have a 245/40-18? That would be better.
Wierd that the wider tires are cheaper...
Old Feb 28, 2006 | 09:01 PM
axe281's Avatar
I put 245/40/18 on mine. You will have a broader selection of tires in htis size. I chose Michelin Pilot Sport A/S and they are great
Old Mar 7, 2006 | 12:00 PM
RX8 JET's Avatar
Did you only put the 245s in the rear or all around?
Old Mar 7, 2006 | 09:04 PM
axe281's Avatar
All around.
yurcivicsux
192
Sep 12, 2017 10:54 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
CMRine04
Sep 17, 2015 10:04 AM
