n2o
Old Feb 23, 2006 | 07:45 PM
barondidit's Avatar
DREAMER
n2o
how much of shot can the auto take 120?
Old Feb 25, 2006 | 07:35 PM
DOMINION's Avatar
I don't buy Kool-Aid
IMO I would prob not use N2O, But thats just me.
Old Feb 25, 2006 | 10:13 PM
therm8's Avatar
Bummed, but bring on OU!
that much N20 would require larger injectors and engine management, but if it's set up right, I don't see why you couldn't do it. It would be better to start small and work your way up to it though. The auto has much less fuel available than the 6spd on the stock injectors.
Old Feb 26, 2006 | 05:28 AM
rgonza's Avatar
Rob gonzalez
It can handle up to 175, i was used in my rx8 science it was A/T and it is very fun to drive it was installed a ZEX kit it work fine and safe for this application. For the fuel this kit use it fuel from fuel injectors line that's independent from the engine injectors because this system is a wet system and pump is the same as 6 speed have.
Rgonza
Old Mar 10, 2006 | 09:38 PM
virus's Avatar
Yo man,
I am planing to install a NOS system in my auto 8 as well ...any advise or what is the setup like ? Do i need to tune my ecu or get a piggyback ecu?
Pls advise
Old Mar 11, 2006 | 07:12 PM
Fanman's Avatar
175 shot ? I would like to see that. The 6 speed MT are having trouble getting past 55-75 shot wet system. Unless it is a severe direct port unit with the timing drastically different not seeing a 175 shot on this engine. Have you done it ? What was involved (engine management, injectors, etc) ?
Old Mar 12, 2006 | 11:56 PM
SWVA_RX-8's Avatar
Purge Addict
I am running a 55 shot on my with no problems I am planning on going to a 65 shot as soon as I get my underdrive pulleys installed. I would just be careful and increase it in small increments
wilo
Series I Engine Tuning Forum
26
May 10, 2016 05:31 PM
ctsvbeast
NE For Sale/Wanted
Aug 8, 2011 08:25 AM
hoole
15
Mar 18, 2010 08:13 PM
krijpipudht
Apr 14, 2009 06:57 PM
Dietbudda
Nov 19, 2008 09:16 PM
