noob question
Old Feb 22, 2006 | 08:12 PM
W1CK3Dninja's Avatar
noob question
what bolt on's can i get without having to tune it? also what bolt on's actually have proven horsepower gains? i have experimented with a lot of honda cars and most people just think it's faster just because it gets louder. from my reading on this site, a midpipe and a exhaust is good proven power adders, and from what i interpret an intake doesn't do much. how do you get the cel light off if you have a midpipe?
Old Feb 22, 2006 | 08:42 PM
expo1's Avatar
He's as bad as Can
Midpipe+Exhaust = maybe 10 HP, more noise, a CEL and $1,000 less in the bank.
The RX-8 doesn't respond well to " bolt-on's ", Mazda did a dam good job on this car. It's not easy or cheap to improve on stock.
Old Feb 22, 2006 | 09:06 PM
NoTears316's Avatar
Shock and Awe
I've replaced my intake, exhaust, midpipe, and pulleys and have never thrown a CEL in over 2 1/2 years (except when my SR cat fell apart). Even though they are called "bolt-ons", you still have to take your time and install it correctly.
Old Feb 22, 2006 | 11:07 PM
so the midpipe will not throw a cel? i was looking at the exhuast, cat combo from turbo XS and it showed a dyno gain of 25whp. that's just hype right?
Old Feb 23, 2006 | 05:51 AM
Jaguar_MBA's Avatar
Aluminum Flywheel.
WWW.RACINGBEAT.COM
WWW.RX8store.net
Old Feb 23, 2006 | 07:49 AM
toca's Avatar
A High Flow Cat Midpipe Wont , But A Cat Delete Mipe Pipe Will.
Old Feb 23, 2006 | 08:11 AM
FLybOi drE's Avatar
thats not necessarily true...it alllllll different on every car. when i experimented with the sr high flow cat...it threw a cel immediately...then when i switched to the b&b testpipe...i ran for about 3months without a cel...then bam, i got a cel...so theres no rule about it that's set in stone. some get lucky with it, some dont...
Old Feb 23, 2006 | 08:24 AM
well i'm gonna have a straight through testpipe, because there is no emissions in florida. what do i have to do to fix the cel light if it does go off?
Old Feb 23, 2006 | 10:35 AM
FLybOi drE's Avatar
man...i wish i lived in florida!!!...anyways, there are no definite fixes to the cel, some have tried to get rid of it by tuning but still came back on, its just that our ECU is just wayyy too smart...i say just live with it...you might get a cel, you might not...
Old Mar 1, 2006 | 04:27 AM
Armaant's Avatar
Armaan
i actuality no its not just hype...considering it was my car that made those gains on the low end and about 34whp peak...search for my posts on the turboxs system and check all the info... i'm very satisfied...it does throw a cel though regarless of the "fixes" that are availabke. i have cleared the cel numerous time and believe the problem is with the brakes now which need to be replaced....overall i would reccomend this system but you probably will have to deal with the cel and the fact that it is pretty loud.
Evan Gray
Nov 24, 2015 01:00 AM
nferguson88
Oct 6, 2015 12:45 PM
pjwermuth
Sep 28, 2015 11:36 PM
kody59
Sep 28, 2015 03:43 PM
Learners_Permit
Sep 27, 2015 07:38 PM
