View Full Version : DIY: Shock Sensor Install
B-Nez 08-06-2003, 11:46 PM Here are my notes from installing the shock sensor this evening. The entire job took about 20 minutes maximum.
Kit Contents: Instructions, Shock Sensor, Wire harness, wire taps, zip ties.
B-Nez 08-06-2003, 11:47 PM Here is a closeup of the Shock Sensor itself (sorry it's a bit blurry).
B-Nez 08-06-2003, 11:48 PM You remove the plastic panel near the passenger side footwell. Here is what the back side and clips look like.
B-Nez 08-06-2003, 11:49 PM Here is another shot of the panel, showing the piece that sits under the plastic doorsill, and its clip that goes under the rubber weatherseal.
B-Nez 08-06-2003, 11:50 PM Here is the passenger footwell with the panel removed.
B-Nez 08-06-2003, 11:51 PM On the 14-pin connector (up high - top right of photo) use pliers to snap 1st wire tap onto BLUE/RED wire.
B-Nez 08-06-2003, 11:53 PM From the sensor harness, snap the RED wire's male connector onto the wiretap.
Note: In this photo the connector is NOT seated fully. The sleeve must contact the rear face of the wire tap, and should audibly snap.
B-Nez 08-06-2003, 11:53 PM Still on the 14-pin connector, snap another wiretap onto the BLACK/YELLOW wire.
From the sensor harness, snap the ORANGE wire's male end onto the wiretap.
B-Nez 08-06-2003, 11:54 PM Move to the lowest visible connector - the 5-pin ground connector. Attach a wiretap to any BLACK wire on this connector.
From the sensor harness, snap the BLACK wire's male connector onto the wiretap.
B-Nez 08-06-2003, 11:56 PM Now locate the 24-pin connector for the keyless entry module. It is the center of three, vertically placed connectors. Snap a wiretap onto the BLACK WIRE WITH BLUE STRIPE.
Pay close attention, because there is also a blue wire with a black stripe.
From the sensor harness, snap the BROWN wire's male connector onto the wiretap.
B-Nez 08-06-2003, 11:56 PM Your completed connections should look something like this.
Plug the sensor harness into the shock sensor and zip-tie the sensor to the far bundle of wires (keep the sensitivity knob pointed for easy adjustment). Use the other zip-tie to bundle your loose wires.
B-Nez 08-06-2003, 11:57 PM The completed work, with footwell panel reinstalled should look something like this. Adjust the sensitivity as required.
dcfc3s 08-07-2003, 10:40 AM Dang, Wayne, already got the '8 all hooked up! :)
I wonder if that shock sensor is a commonly-available aftermarket unit - might be able to find it cheaper.
How much was it from Mazda anyhow?
Dale
B-Nez 08-07-2003, 08:16 PM I paid $55 at the dealership, and saved $75 by installing it myself. Cutting the pennies to justify to the wife dropping coin on the factory service manual. And to justify the upcoming tint job.
colin204 08-07-2003, 08:18 PM can you scan the directions and post them?
RX-Nut 08-07-2003, 08:52 PM Pardon my ignorance.. what does the Shock Sensor do?
B-Nez 08-07-2003, 08:58 PM Originally posted by colin204
Sure, but gimme a day or two - really busy right now. The only reason I didn't scan initially is because the sensor comes with the instructions, and my remarks were meant to supplement said instructions.
B-Nez 08-07-2003, 09:00 PM Originally posted by RX-Nut
The shock sensor detects shock/impact to the vehicle and trips the alarm when such a shock/impact is encountered. In many cases, it let's you know when it is storming outside when the thunder trips the alarm (people leave the sensitivity too high).
So I guess you need the alarm to get the sensor? I don't think my car has an alarm. I really don't know :shrug:
B-Nez 08-08-2003, 12:52 AM Originally posted by Wing
Try this procedure:
Roll down a window.
Close the doors.
Lock the doors with your keyfob.
Reach in through the window and open or unlock the door from the inside.
If the car goes apeshit, then you have the perimeter alarm.
eccles 08-08-2003, 01:19 AM Originally posted by B-Nez
Roll down a window.
Close the doors.
If the car goes apeshit, then you have the perimeter alarm. You don't even need to leave the car. If you remove the key from the ignition and use the remote to lock the doors while you're still inside the car, the alarm will sound when you try to exit the vehicle. I speak from personal experience. :)
Yeah, I read that in the manual. I didn't try it but I don't think I have it.
Stated in the canadian specs the GT comes with an alarm the GS does not :(
I'm thinking about getting an alarm, but then I think it's useless. Once someone breaks in, it's too late anyways.
They would have to fiddle to defeat the ignition kill. And they have already done damage to the car in some way at that point anyways.
The best theft deterent is the flashing red light that blinks when the key is out.
I will try that trick tonight but I don't think it will go off. I wonder how much it is for the mazda alarm.
Or another question is, I wonder if it's easy enough to get an aftermarket version that works with my current keyfob and door locks/trunk etc.
Thanks for this info, waiting for the feature to be avaialbe, I just may try it myself and save the install charge too!!
Plus, I really do not like people working on my car for stuff like that.
A little off subject, has anyone experienced a rattle form the sun roof? When driving in the city, the interior roof cover vibrates alot, and I think it is the lighting that is rattling. Noise does not change if I open, close or tilt the roof or the sun shade.
Any ideas? It drives me crazy!!
doug
RX8 Pusher 05-20-2004, 11:36 PM B-Nez,
Props for the install pic and additional data! You just saved me $85 that a dealer was going to get tomorrow!
Best Regards
All GT's have the alarm system
Hard 8 05-27-2004, 04:35 PM Originally posted by Doug
A little off subject, has anyone experienced a rattle form the sun roof?... It drives me crazy!!
That's WAY off topic. :D But I recall reading a looooong thread months ago, where a lot of people had that complaint. Try a search; maybe it contains some solutions.
timisw 05-29-2004, 06:18 PM Great job with the instructions! You saved me money as well! Great pics and instructions.
Any difficulty getting the side panel off or back on? I know how cheesy those plastic clips can be sometimes! I havent looked at it yet, but if you have any other tips with the panel, the rest shoudl be a breeze!
How do you like the shock sensor now that it is installed?
RX8 Pusher 05-31-2004, 11:21 AM Timisw,
The side panel just kind of pops on and off. Kind of hard to describe in a step by step set of instruction. Darn thing came off and went back on so easy that I am not sure I could tell you were I tugged or pushed…
I know that you posed the question about “how much do you like it” to B-Nez and I am sure he will favorably reply soonest, but I followed his lead and installed mine without trouble (much) and it’s functions work as advertised. I have left mine on “high” sensitivity and plan to adjust as needed. (Unlike the install pic, I placed my shock sensor IAW the provided instructions along the wire harness inline with the blower fan and can access mine to adjust the settings without removing the side panel.) At it’s current settings (highest) if you try to access the car by lifting up on the door handle and then let it go once you find out it is locked, then the alarm with go off…(my 5 year old found this out while trying to get his fruit drink out of the car). Additionally, if you tap on the front headlight covers the alarm will sound. Obviously, this high setting will be problematic during thunderstorms and I will fine tune this over the next couple of weeks.
There is a slight delay from the time of impact until the alarm goes off (approx 1 sec or long enough for you to think…”it is not going to HONK, HONK, HONK”…it works). One word of caution……read B-Nez’s and the provided instructions carefully, as the 24 pin connector is way up in the dash and do not get fooled by the connector that will be staring you square in the face during the install. While you will wish a hundred times it was the right one, and it even has a “brown” wire, etc…..it is missing the biggest clue being displayed by the correct connector, and that is a big yellow sticker indicating the keyless remote.
Thanks again to B-Nez for the initial info and pics….Regards
Smoker 05-31-2004, 01:58 PM Maybe the Mods can move this thread over and make this an official DIY thread
timisw 05-31-2004, 03:02 PM Thanks... going to order it on Tuesday. With these instructions its going to be an easy $75 that they dont get for an hours worth of work that really only takes 20 to 30 minutes!
rx8cited 05-31-2004, 05:41 PM Originally posted by RX8 Pusher
.......... I have left mine on “high” sensitivity and plan to adjust as needed. (Unlike the install pic, I placed my shock sensor IAW the provided instructions along the wire harness inline with the blower fan and can access mine to adjust the settings without removing the side panel.) At it’s current settings (highest) if you try to access the car by lifting up on the door handle and then let it go once you find out it is locked, then the alarm with go off…(my 5 year old found this out while trying to get his fruit drink out of the car). Additionally, if you tap on the front headlight covers the alarm will sound. Obviously, this high setting will be problematic during thunderstorms and I will fine tune this over the next couple of weeks. ........
RX8 Pusher,
How do your arm your alarm? :) .
Here's why I'm asking - I found that with my shock sensor set at maximum sensitivity, if I tried arming the alarm by pressing the door lock switch inside the car prior to exiting the car and closing the door, the alarm would not arm (hazard lights would not flash). I guess the sensor was outputting "shock present" due to the vibration of the car during/after closing the door, and the alarm logic does not like to see that when going from unarmed to armed state - so it does not arm.
Arming the alarm by pressing the lock switch on the fob after closing the doors worked fine - so I'm guessing that you use the fob.
Would you mind trying locking with the interior lock switch and let me know if the alarm arms or not please?
I realize this is a non-issue if the fob is used to lock/arm the car. I wish the alarm system was designed so it delayed momentarily after the door was closed so as to not get confused by the door closing vibration.
Here's a thought for you on keep your sensor at maximum sensitivity: When I installed my shock sensor, I decided to wire a bypass switch into the sensor circuit in case it went off during thunderstorms - but I don't have the sensor set to maximum sensitivity anymore because of the no-arm with interior door switch issue. At its current sensitivity setting, the alarm has not gone off during storms, so I have not used the bypass switch. The bypass switch allows the sensor output to be disconnected from the alarm system.
Depending on the frequency of thunderstorms, it my get tiresome to have to flip the bypass switch ..... so probably fine tuning your sensitivity setting as you mentioned is the better option :D.
Another forum member mentioned that their alarm had gone off serveral times and a neighbor got pissed and egged the car.
rx8cited
timisw 05-31-2004, 07:14 PM Quick Question...
If the Shock Sensor sets the alarm off, how long does the alarm go off for? Is there a setting or does it keep going off until EVERY neighbor is armed with an egg?
B-Nez 05-31-2004, 09:46 PM Originally posted by timisw
Sorry for the delay in my response - we just moved into our house and got the bulk of the unpacking done.
1) Installation: Do note that the units now shipping are a bit different as to have the diode kit. So my instructions may be off. I suppose they are still good to give you an idea of how simple it is and what to look out for and avoid. Someone posted updated instructions on here somewhere...I recommend searching for that.
2) How do I like it? Well, I had it on min. sens since it was an original unit that clicked and flashed while driving. I finally had the dealership install the diode kit, but now it won't trip the alarm no matter what I do. Someone suggested they may have reversed the diode and it's a simple fix. I haven't had time to mess with it due to the move, so for now it hasn't been functioning as far as I know.
rx8daniel 05-31-2004, 10:21 PM I need a little assistance. I believe I installed the first two taps incorrectly. I used the wires that go up to the middle connector towards the top (one would connect to the red of the sensor). I believe where I wanted to install the taps is the wires coming out of the bottom of the "14-pin connector" that seemed to really only have 5 wires coming out of it. It was terribly more difficult to install them where I did. My plan now is to buy more taps, install them to what I believe to be the correct wires before I plug the sensors into them. Actually I think I plugged the very first tap to yet another incorrect wire. It got very frustrating- I studied the instructions and the pics here before trying to mess with it. I gave up after at least an hour of messing with it. It sure looked simpler in the pics- but they can't show everything.
B-Nez 06-01-2004, 12:19 AM It sounds like you're not looking high enough into the footwell. Get your head up in there with a flashlight, you'll find it - it's a monster. At the top of the photo below is a bundle of 14 wires going to the connector. The connector with the lever-looking thingy on it is not the one. Look even higher and further back...it's closer to the firewall.
rx8cited 06-01-2004, 06:48 AM Originally posted by timisw
Quick Question...
About 3 minutes from page 3-23 of the Owner's Manual.
Here's the egging story (http://www.rx8club.com/showthread.php?s=&threadid=29232) .
rx8cited
Moloko9 06-01-2004, 04:49 PM I put this unit in about 6 weeks ago. I've been having an awful time with False alarms. No vibrations or anything, I have it turned all the way down, and it will just go off by itself. It's happening daily at least.
Has anyone else had this happen or know of a possible cause?
rx8cited 06-01-2004, 06:04 PM Originally posted by Moloko9
0) What happens if your alarm is armed and you hit the windshield lightly with your palm?
1) Double check that the sensitivity control knob is turned all the way counterclockwise to minimum sensitivity. Arm the alarm and hit the windshield lightly with your palm.
2) If alarm did not go off, you're onto something. If that caused the alarm to go off, repeat step 1 with the knob all the way clockwise to maximum sensitivty.
3) If the alarm did not go off - hmmm - left is right and right is left? If it still went off, set knob back to counterclockwise position and recheck your sensor installation/wiring. If you find an error, go back to step 1. If no wiring/install error, maybe a bad sensor unit?
rx8cited
RX8 Pusher 06-01-2004, 07:46 PM Day 4, new upgraded shock sensor w/diode, max sensitivity, 3 storms and only 1 false alarm ……..no eggs!
RX8cited,
I tried the door lock test that you asked for. My alarm is acting like yours and will only arm with the use of the key fob. Manually locking the door will not arm the alarm. Fortunately, you pointed this out to me before I learned the lesson myself.
B-Nes,
Thanks again!
RX8Daniel,
I am sorry to hear that you are having problems. I can only suggest this approach (the way I did it): read the entire provided instruction booklet and prep all of your kit by placing the connectors on the diode and the additional clip on it as well, then refer to B-Nes’s excellent DYI instructions and compare the instructions with the colored pictures. Make some notes if you need to, then go to the car and identify the different wiring harnesses. (They are the high one’s not the easy to reach low ones…except for the grounding wire) Draw a picture of that if need be and then return to the color pictures and reference the instructions or make colored prints of the pictures and reference them at the car. The hardest wire for me to reach was the brown wire for the diode coming out of the key remote connector and there is a big yellow sticker identifying it. The drawing of the diode with the instructions is somewhat misleading, as that wire does not hang down but is stretched tightly into the wiring cable harness. Good luck and keep us posted.
rx8cited 06-01-2004, 09:50 PM Shock Sensor owners,
If anyone here has the pre-diode fix version of the Shock Sensor Installation System Wiring Diagram (it's one page from the shock sensor kit installation instruction booklet), and can scan / post it for me, I'd really appreciate that.
I'd want to see how it differs from the diagram I have which includes the diode fix.
Thanks,
rx8cited
PS: RX8 Pusher, thanks for posting your results to my requested test.
RX8 Pusher 06-03-2004, 10:36 PM RX8Daniel,
How is that shock sensor DIY coming along?
CRX Millennium 06-22-2004, 02:52 PM I recently installed the upgraded kit and would like to say that the experience was both horrifying and painstaking. In order to spare you from my account of the installation filled with colorful languages, I just want to point out a few important areas for those brave (or foolish like me) enough who wish to tackle this supposedly "DIY" project.
For starters, the blue/red & black/yellow wires are found on the white 14pin connector, which sits to the right of 3 vertically placed connectors looking from passenger seat to the kick panel. The blue/red wire can be somewhat tricky since there's a similar colored one. Next, the diode preparation should be done exactly described as on the instruction, while only closing up one side of open tunnel on the red gizmo. The brown wire the diode connects to is found on the largest connector that sits in the center of 3 vertically placed connectors. The connector is the control module for keyless entry system, which is marked by Visteon yellow sticker. As other members pointed out, the brown wire is extremely taut and short that is surrounded by a bunch of wires further limiting your access. It took me forever to identify, cut (while saying prayers), and hook the diode to the brown wire using the gizmos on both ends in proper orientation (keyless entry module & vehicle harness going into firewall). I have slim fingers and still found the space to be a major problem as I tried numerous positions to make the connection, ie: lying on my back against the side of passenger seat & door rail. Lastly, the black (grounding) wire can be any of those found on the semi-transparent-white connector sitting closest to the door opening all the way to the right. I can scan the instruction but it's useless as far as I'm concerned.
Godspeed!
Positron 07-04-2004, 02:55 PM Thanks for the pics & posts about the shock sensor install. I did it today (actually my 15 year old son did it for me, I just supervised) and it went very smoothly. It took about 1/2 hour. I have the new sensor with the diode. With successes like this one, we are ready to move on to other mods!! :D
mm
StealthTL 07-04-2004, 04:08 PM For Mr. RX8cited, here is a (crappy) scan of the wiring of the 'first edition' sensor, that falses all the time.
Sorry about the quality, the paper is very thin, and I suck at cleaning up images!
S
rx8cited 07-04-2004, 11:52 PM Originally posted by StealthTL
S
Hi StealthTL,
Thank you, thank you! :) I guess patience does pay, eh?
Lemme' guess, you ended up at this thread after seeing my reply to apaul in the Canada Forum?
Thanks again - the image quality is good enough for my needs.
regards,
rx8cited
10kRPMS 07-25-2005, 08:37 PM Thanks great instructions, I had it installed and working in 20mins.
oraycle 08-19-2006, 06:36 PM I've tried following these instructions and failed miserably. I can't seem to find any of the described connectors. The only one I can find is the one with the black ground wires.
Does anyone know if they changed the locations of the wiring connectors in the 2006 models? Better yet, has anyone done this install on a 2006 RX-8?
RX8 Pusher 08-19-2006, 10:13 PM Oraycle.....not sure what the problem is, the instructions had mine working with minor problems. I have to admit I tried to connect to the wrong wires the first time due to my own lack of attention. Made a copy of the instruction the second time and had no issues when I decided to follow the instructions.
Cheers
oraycle 08-21-2006, 01:49 PM Oraycle.....not sure what the problem is, the instructions had mine working with minor problems.
As I mentioned, I suspect the problem is something changed in the 2006 model. I'll try posting some pics so you guys can see what I'm talking about, but the right side of the passenger footwell only has 2 white wire connectors. One I've identified as the black ground wires. The other one right next to that is the one that has the misleading , but wrong wires. It looks different from the posted pictures (does not have the grey lever thing), but it is in the same locaiton. Looking up above those two connectors, I was expecting to find the described white connectors (either the 14 wire one or the 3 vertically placed ones), but there are NO other connectors up there.
As I mentioned, I'll post a pic later so you guys can see what I'm talking about. But if anyone has done this install in a 2006 and can confirm or refute that the wire connectors have moved, I'd appreciate it.
oraycle 08-27-2006, 11:32 PM Attached are the photos of the right footwell in my 2006 RX-8. The first photo shows the 1st large white connector that used to have a grey lever on it. Obviously, it has changed slightly from previous years. Next to that connector is the one with the black ground wires.
The second picture shows further up above the 1st large white connector (it partly appears at the bottom center of the photo).
The 3rd picture shows even further up above the 1st large white connector.
Reading the earlier posts, I was expecting to find a 2nd large white connector somewhere above the 1st one. And also 3 vertically placed smaller connectors. But as you can see from the photos, there are no other white connectors above the 1st large white one.
holy crap! those photo's look nothing like what my car looked like! And I just did the install today! I was actually surprised to see this DIY even up... It's actually pretty simple, but I will have to admit that I had my moments of frustration, only to realize how in depth the directions took me.
Anyway, call some people and start asking them about the 06 model shock sensor, or call the people you bought that sensor from...
Hmmm ... are you sure your RX-8 even has an alarm (I really dunno if all the RX-8 come standard with it or not)? I have a 2006 Shinka and my right-front foot well doesn't look anything like yours --- mine has wires and harnesses all over the place. I haven't installed my Shock Sensor yet so I'll take some pics when I do. From what I can determine after inspecting my foot well, the gray connector (in your 1st pic) is the 14-pin connector with the blue/red and black/yellow wires as describe in the Installation Instructions. It looks like they've moved the 14-pin connector from the previous position which was higher up in the foot well (your pic 3) to its current lower position. The white connector (in your 1st pic) is the 5-pin ground connector moved to a more forward and lower postion than in the previous RX-8 models. The 24-way connector seems to be in the same position as stated previously in the DIY and the Installation Instructions --- buried way up high on the firewall (in the area of your pic 2) :sad: Looks like I'll have to cut off the electrical tape wraps on that harness to find the brown wire. I also have the white connector with the gray lever-thingy somewhat above, but between the two connectors in your pic 1.
I'll post when I install my Sensor.
oraycle 09-12-2006, 05:06 PM Hmmm ... are you sure your RX-8 even has an alarm (I really dunno if all the RX-8 come standard with it or not)?
Yeah, it came with the standard alarm (horn sounds if you open the door while it is locked), but not the shock sensor upgrade. A previous post suggested I contact the dealer I bought the sensor upgrade from and I'll probably do that (haven't gotten around to doing it yet).
nycgps 02-28-2007, 02:43 PM Im trying to install the shock sensor as well. Damn, I have no idea where the fuck is the brown wire (cant find it)
and also Im afraid that I might *cut* the wrong wire and fuck myself up, cuz the instruction saids I have to CUT the brown wire, and connect both ends to the diode
gonna take a rest, deep breath, and go back in 1/2 hour (making food)
Will post photos when Im done.
nycgps 02-28-2007, 03:58 PM Damn it.
The instruction, I dont know man, but it seems that they probably made that one for 05 only.
and the most important wire, the Brown one, is a damn bitch to locate AND work on. its freaking short, and its really hard to reach
Here is the pic.
Its not so good because its hard to get a good position down there. but just to give ya guys some idea where it is.
konradk 03-02-2007, 05:18 PM great thread! i have an 06 as well, so i guess im stuck like the other 06 owners, but thanks for helping me figure out i had the stock alarm installed! Neither the window sticker nor the dealer said anything about it, yet sure enough, just as i was certain there was no alarm, HONK HONK HONK! :mdrmed:
Mazurfer 03-03-2007, 10:09 AM All I know is that on my 05..............I had all the harnesses in that immediate area exposed for about two freakin hours while I read the directions over and over while trying to figure out just which brown wire to cut. I'm not sure I ever really convinced myself, but finally said "okay..........screw it.........here we go!" It turned out to be the right one, but I was nervous about it. It wouldn't have been that bad(even if wrong one) as I could've just spliced it back together and cut the next one, but I didn't really want to jack it all up.
Alarm works good, but have to adjust per directions..........I had mine too sensitive and any motorcycle within about 20 feet would set it off, as would thunder(not even close by). I finally did the tennis ball trick from 3 feet and that seems about right for me.
bobdobbs 03-29-2007, 09:38 PM This is maddening. Where the heck is the brown wire? My car is an '06 GT. Here's a pic of the wires.
Krasnog 04-14-2007, 04:10 PM 20 mins... hah - that's a good one.
Krasnog 04-14-2007, 04:13 PM this looks like your keyless console here. It's the brown wire coming out of that sucka.
It's more 'open' on the 04... if that's even possible
newcastle 04-24-2007, 11:09 AM I noticed that they revised the unit and they now come with a diode kit. Is this diode a LED (light emitted diode)? Also is the diode integral to the shock sesor device or does it mount remotely? If it mounts remotely can someone please post a pic or a detailed desription as to where the diode mounts.
nycgps 04-24-2007, 12:17 PM it taps between the shock unit and to the remote access thing (the box that controls the door lock and stuff)
I think .... Im not 100% sure cuz I threw my instructiojns away already ...
but I think they starting year 05, they try to seal the wires with tape ... making it a bitch to work at, I've seen some 06 they're completely sealed ....
I had to lie down on my sit , upside down for like 1/2 hour before I can finally be able to tap the wire to the key box(forgot what it was called) , its a tiny ass wire.
nycgps 04-24-2007, 12:22 PM This is maddening. Where the heck is the brown wire? My car is an '06 GT. Here's a pic of the wires.
Its the brown wire that comes out of the Black box (key control console).
Hope its not too late.
Jedi54 04-24-2007, 01:01 PM looking at all those wires and trying to find the brown one reminded me of Where's Waldo. :)
I'm thinking of doing this on my '05 but it looks like Mazda has thrown us a bit of a curveball.
titaniumgr3y 04-27-2007, 01:37 PM Guys, my car is RHD, and i think that there is a problem.
Could anyone help me?
I got the brown with diode but i didnt connect it.
Is this why my shock sensor didnt work?
The red led on the shock sensor, will it turn on at some point?
titaniumgr3y 04-28-2007, 05:14 PM anyone to help here?
on the RHD will it still be on the passengers side or will it be to the right side which in my case is the driver's side?
i have found the red/blue,yellow/black,black/blue and black on the drivers side/right side.
I dont know why is not working.
titaniumgr3y 04-29-2007, 08:14 AM ok i realized that the only cable that it was connected correct is the ground, i connected the red one correct, i will continue on tuesday the project.
My car is 2003, will i need the brown diode ?
titaniumgr3y 05-11-2007, 02:50 PM guys i think i have a problem with mine as it is a RHD.
I think they have differences with LHD.
Anyone installed it?
nycgps 05-11-2007, 03:06 PM there shouldnt be any differents between RHD and LHD. at least in terms of wiring.
You have to connect all of them. dont leave the brown one non-connected
See if you can find the same group of wires on the left side.
titaniumgr3y 05-13-2007, 02:25 PM the ground + 12v are ok.
the brown + orange.. i dont know
nycgps 10-29-2007, 03:06 PM Still cant find it ? :)
ShellDude 09-28-2008, 10:20 PM DIY revival!
I ordered mine for my 04 4AT tonight....
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&viewitem=&item=220162036872
Jedi54 09-28-2008, 11:40 PM i think that stolen wheel thread will lead to more sales of this.
ShellDude 09-28-2008, 11:41 PM heh... u jedis are pretty good.... that's exactly why I ordered mine.
newcastle 10-05-2008, 01:20 PM heh... u jedis are pretty good.... that's exactly why I ordered mine.
Ditto....installing in about 30min....will post feedback.
newcastle 10-05-2008, 03:07 PM Done. Install time was inclusive of testing and a coffee break. That brown wire was very difficult due to space limitation and the length you had available to work with.
Note: I have a 2004 GT
mysql 10-05-2008, 03:36 PM This is maddening. Where the heck is the brown wire?
The directions aren't only not clear, but the illustrations only add to the confusion.
To help, I color coded the wires to help clear up with the illustrations was trying to show:
http://rotaryinsider.com/rx8-58.html
Jleorx8 10-05-2008, 07:55 PM done on 20 min, the hard is to find the brown wire, when you find it is to them short, :spank:
ShellDude 10-05-2008, 08:24 PM I'm headed out to the garage to brave my install now...
ShellDude 10-05-2008, 09:44 PM All done. Knowing exactly what harness the brown wire was in helped quite a bit, and being that it was hangin' out clear as day leading out of the harness it was then just a matter of cutting back the electrical table holding the wires leading to the harness, snip snip for brown, then I was back on my way.
Thanks for the DIY, and the additional illustrations. This thread made the install a breeze. The combination of the Mazda documention and pictures / clarifications here make this install practically trivial.
Andreas Neophytou 12-16-2008, 10:33 AM Really sorry guys but I cannot find the brown wire on a JDM RHD
RyanX-8 12-26-2008, 02:39 PM I think I got it. Not as sensitive as I thought.
Rogueain 02-07-2009, 12:25 PM Diode Install --
Make sure when installing the diode, that you follow the instructions. They're a little hard to understand, but incorrect wiring can short out the shock sensor module, and it will need to be replaced.
Make sure when looking for the brown wire to cut, you look real hard, because there was an orange wire right next to it, and they're VERY similar in color. Also, when you wire in the diode, make sure the side with the sticker on it, (The longer wire) is attached to the upper end of the wire going into the remote alarm, while the short end is going into the lower wire harness.
Lastly, make sure that when you clip the wires into the splitters, no loose wires are coming out the other side, they can cause a short, or quite possibly a fire if they make contact with metal or other wires.
EDIT: Cutting the black tape about 1/3 the way down made the install much easier, it gave me enough slack on the brown wire to get my hands up in there. Good luck with getting a pair of pliers up in there, happy modding!
Mazurfer 02-07-2009, 12:46 PM ^...........+1, I was gonna tell him all that, but now I don't have to type it!
Rogueain 02-08-2009, 11:15 AM For those of you who have a clicking issue when arming your alarm, I went ahead and installed the Diode kit that came with my shock sensor package. It's a PITA to install, but it corrects the clicking issue (Door locks click 10 times when arming alarm).
Make sure when installing the diode, that you follow the instructions. They're a little hard to understand, but incorrect wiring can short out the shock sensor module, and it will need to be replaced. Make sure when looking for the brown wire to cut (Way up into the highest harness), you look real hard, because there was an orange wire right next to it, and they're very similar in color. Use GOOD lighting! Also, when you wire in the diode, make sure the side with the sticker on it, (The longer wire) is attached to the upper end of the brown wire going into the remote door lock mechanism, while the short end is going into the lower wire harness.
Also, make sure that the wire splitters don't have loose wires coming out from the ends. With this info, you should be able to do this diode rewire easily. FOLLOW THE INSTRUCTIONS!@!!%#
Edit: Ran into a problem where my alarm was not functioning correctly. After some trial and error, I realized that we do not get neat dashboard warnings that the trunk is open. My trunk was not closed all the way. Shut your trunk hard before you do this :D
TheBlackmobileR3 05-27-2009, 03:36 AM I wonder if this is available for the 09...... hmmmmmmmm
rx8cited 05-27-2009, 08:25 AM According to FinishLinePerformance (http://www.finishlineperformance.com/store/product.php?productid=16844&cat=267&page=1)it is, but I'd follow that up with a phone call to verify b4 ordering.
Note that it says "Fits: 2004-2009
Not for vehicles with advanced keyless."
BTW, I've never seen them at this low price, so jump on it if you want one and they confirm it will work with your car. Don't rush during the install as you can tell from this thread :).
PIS2NLESS 09-17-2009, 10:38 PM Is this going to work with cars that have advance keyless?
has anyone tried it?
Mazurfer 09-18-2009, 09:32 PM I don't believe that it will.
Take a look here.............. http://www.finishlineperformance.com/store/product.php?productid=16844&cat=267&page=1
