Shock Sensor ?!?!?
Old Feb 22, 2006 | 01:51 PM
UgE's Avatar
UgE
Angry Shock Sensor ?!?!?
I've purchased the "Shock Sensor" upgrade...
It works great but there is something wierd about it :
It is activated as soon as the ignition is not in the "ON" position.
What I mean by activated is that if there is some sort of movement,
interior dome lights will blink, but the alarm system (with the horn and
everything) will go off until I lock the car....... i think
HOWEVER, it gets pretty annoying when I want to stay in my car and, for
example, listen to radio... the lights keep blinking except when in the
"ON" position...
But last week I tried to go to the "drive-in" movie... now it made
things impossible ! Normally you would let the ignition on the "ACC"
position but if I did that the interior lights were blinking during all
the movie... except if I set the sound to a barely audible level... so I
had to keep the ignition in the "ON" position and have the really flashy
WHITE GAUGES in my face during all the movie...
Is it installed correctly and is there a solution??
And by the way, IS IT NORMAL that the dome lights flash when there is a movement... like when I get in my car and close the door, those lights flash... (except the key is in the ignition and on the "on" position)
Thanx
Old Feb 22, 2006 | 02:03 PM
zoom44's Avatar
why not switch the guages to red?
Old Feb 22, 2006 | 02:08 PM
deamicls's Avatar
that's what I was thinking.
Old Feb 22, 2006 | 02:10 PM
Glyphon's Avatar
脾臓が痛みました
well, supposedly the shock sensor has adjustable sensitivity, so maybe try playing around with that.
Old Feb 22, 2006 | 02:12 PM
Glyphon's Avatar
脾臓が痛みました
Originally Posted by Cool-Blue-Dad
Can that be done without turning on any exterior lights? I'll have to try it.
UgE, I have the shock sensor upgrade too, but I have never noticed the dome light to flash. I'll experiment with mine tonight and report back.
yup, its the ****/roller that is next to the DSC switch. set it any time.
Old Feb 22, 2006 | 02:19 PM
Glyphon's Avatar
脾臓が痛みました
Hmmm, never rolled all the way that way. I usually click it the other way to 'force-white' when I have headlights on early in the evening and find the red just too dim.
yeah, i always have it set on the white display setting for the same reason.
Old Feb 23, 2006 | 10:36 AM
UgE's Avatar
UgE
Exclamation
Yup please do, I really wanna find out if it's normal at all :-S !!!!
ThX ! UgE
Old Feb 23, 2006 | 11:12 AM
dsmdriver's Avatar
There's probably a fuse you could pull that would fix this during a drive-in.
Old Feb 23, 2006 | 11:25 AM
mysql101's Avatar
there's something not right ... I have had the shock sensor in my car since i bought it. It only activates when I enable the car alarm. And the car alarm doesn't enable when the key is in.
zoom44's Avatar
damn i knew this sounded familiar- you guys have the OLD shock sensor system which had an issue with this. It was actually taken off market and a NEW version brought out. There is an update kit to fix it by putting in a diode. Here is the TSB
http://www.finishlineperformance.com...7-04-1281a.pdf
RX8 - DOME LAMP FLASHING AND / OR CLICKING SOUND FROM REAR DOORS
APPLICABLE MODEL(S) / VINS
2004 RX-8 (with Mazda Genuine Accessory theft-alarm shock sensor installed)
DESCRIPTION
Some customers may experience a concern of the dome light flashing or a clicking sound from the rear doors
when a front door is closed. The cause may be an due to a missing diode in the early version of the Mazda
Genuine Accessory Theft-Alarm shock sensor installed in the vehicle.
Customers having this concern should have their vehicles repaired using the following repair procedure.....
Old Feb 24, 2006 | 11:37 PM
UgE's Avatar
UgE
Oh man that SUCKS my RX-8 is a 2005 !!!!
There's some mazda dealer who's gonna hear about me...
Man that really sucks ! Thank you so much Zoom44 !!! You rock !!
I even emailed Mazda and they had no clue about it !
Thanks !!!!!
Old Feb 24, 2006 | 11:51 PM
Xeres's Avatar
Is the shock sensor an option to the standard Antitheft system? I was never really sure what the hell it did. And you guys that have it do you think it is worth getting?
Old Feb 25, 2006 | 10:20 AM
BunnyGirl's Avatar
It's an extra option for around $60 (can't remember exactly, my order receipt is not in front of me). I ordered it for mine and think it's a good idea. My luck, though, one of the random cats around here will probably manage to set the alarm off in the middle of the night and **** off all the neighbors!!!! That would be a real pain, too, since my car will be parking at my neighbors house.
Old Mar 5, 2006 | 07:59 PM
RX-MEN-8's Avatar
This was an option I thought would be great.. I had to have my original changed to the "updated" version...It still stinks.. Unless you turn the sensitivity down, you will get the clicking and dome light effect.. I was forced to turn it down or be driven nuts w/ the noise. This is one case where Japanese engineering did not work out.
92trbolzr
May 18, 2025 09:04 AM
Shankapotamus3
Mar 14, 2021 03:53 PM
tjohnmeyer
Sep 28, 2017 05:03 PM
Evan Gray
Nov 24, 2015 01:00 AM
duworm
Oct 1, 2015 04:57 PM
