Discoloration of the rotors.... not rust, need input!
Old Feb 22, 2006 | 12:42 PM
toxin440's Avatar
hi all...
on my front left wheel the rotor looks like this:
the darker band towards the center is what worries me? is something wrong? do i need to go and get it looked at (whole car is under warrenty)
Thanks in advance!
Jeff
Old Feb 22, 2006 | 03:29 PM
toxin440's Avatar
bump?
Old Feb 22, 2006 | 04:34 PM
Go48's Avatar
The discoloration may be due to differential glazing (from overheating) of the pad, or it might just be a faulty pad. In other words, the inner part of the pad causing the discoloration is a different consistency than the outer edge of the pad. That's speculation 'cause I don't recall seeing that condition before. If the discoloration doesn't disappear after driving the car for awhile you should have the dealer check it out.
Old Feb 22, 2006 | 05:09 PM
valpac's Avatar
Ahead of its time
looks scorched. is that wheel a bit grabby?
Old Feb 22, 2006 | 05:29 PM
toxin440's Avatar
no but i think it (the front left) is the wheel that is always squeaking at low speed stops...
Old Feb 22, 2006 | 05:51 PM
RenKat's Avatar
Not a problem!
I have had this come and go on two sets of pads.
You will see it one day and then the next it's gone.
Old Feb 22, 2006 | 06:23 PM
juikster's Avatar
Im 8 drifting on a budget
I frankly would be concerned for what I see in that pic resembles a nonfloating caliper and scorching ..it appears to show brake pad gouging, (rippling)Take it in .
Old Feb 23, 2006 | 10:15 AM
Joe_914's Avatar
You are glazing your pads and rotors. The RX-8 was designed to the same stopping ability of a Porsche 986. Which means you have "hand of God stopping power"
USE IT. My grandma always applies brakes about a block from the stop light and just drags them all the way. this will glaze the brakes pretty quick and also degrade stopping ability.
Oh and to the Bubba wondering if my wife is hot or not Bite me if you can't read.
400lbs of whompin stompin sexual dynomite.
Old Feb 23, 2006 | 11:09 AM
Glyphon's Avatar
脾臓が痛みました
Old Feb 23, 2006 | 12:24 PM
Krankor's Avatar
Klingon Grammarian
I'll second that:
(looks like he picked the wrong week to give up sniffing glue...)
Old Feb 23, 2006 | 01:25 PM
Joe_914's Avatar
BlueEyes is Offline:
Act as if... Join Date: Sep 2004
Did you just say your wife isn't hot? or am I missunderstanding something?
Do you have a 914?
Sorry I should have put this into better context. But since the thread was closed I could not show my there.
JCTaylor
Sep 30, 2015 07:31 PM
DG07
Sep 28, 2015 10:58 AM
Learners_Permit
Sep 27, 2015 07:38 PM
