cruise control
Old Feb 21, 2006 | 10:16 AM
skhmund's Avatar
THE BITCH IS DEAD
cruise control
does cruise control put any sort of mechanical load on the car?
Old Feb 21, 2006 | 10:27 AM
Asmoran's Avatar
Um. unless you set the cruise at 0 then yes, it loads the engine....
Not really sure what you're getting at. Is it bad to use cruise? No.
Old Feb 21, 2006 | 10:52 AM
skhmund's Avatar
THE BITCH IS DEAD
well i drive about 20 miles hwy at cruise set on 70, my friend said i shouldn't drive at one speed, puts "mechanical load" on the engine going at one set speed, now he's not the most engine-smart person, SO I thought id ask somebody here to challenge his statement
Old Feb 21, 2006 | 11:32 AM
RX-Aight's Avatar
shaaaaaa...
Well for break-in period it says not to drive at a constant rpm for extended times. I'm at 3,000 miles and i use it and love it.
Old Feb 21, 2006 | 11:33 AM
Glyphon's Avatar
脾臓が痛みました
if it does put any mechanical load on the engine, it would be negligle and has also been designed to operate in such circumstances...so ignore your friend, and use cruise control to your hearts delight.
Old Feb 21, 2006 | 11:34 AM
captain mercury's Avatar
Mr. T is my copilot
it doesnt seem right that cruise control would be detrimental to your engine. isnt staying at a constant speed the sole purpose of cruise control?
Old Feb 21, 2006 | 11:43 AM
msrecant's Avatar
Hubble has been saved!
I know of no particular stress put on an engine by keeping the car's speed constant for roughly 20 minutes. On long trips, the constant speed is maintained for hours. Depending on the geography where you live the cruise control will have to vary throttle to maintain speed, thus engine RPM will vary. But even if you live in a flat part of the country I don't see a problem.
The only restriction I am aware of is that during engine breakin Mazda recommends that you do not want to run the engine at the same RPM for prolonged periods. Other than that I can't see what your friend is driving at.
pjwermuth
Sep 28, 2015 11:36 PM
Wurromurro
Sep 20, 2015 05:02 PM
titaneum_grey
Sep 6, 2015 10:21 PM
