K&N Typhoon Installation help
Old Feb 12, 2006 | 12:52 PM
Throwdown's Avatar
Turb O'd
Question K&N Typhoon Installation help
I'm installing this intake right now, and I've run into a problem. It seems that the holes drilled through the heat sheild are too far apart to install the vacuum canister clip.
Did anyone else with this intake find this problem?
Old Feb 12, 2006 | 01:04 PM
WantedTwo's Avatar
C4 burns real good
I don't remember if I did or not but one hole is more than enough to hold a vac canister. hust crank her down and call it a day.
Old Feb 12, 2006 | 06:03 PM
OBTIQ's Avatar
>> Motion
well you'll just have to get a new screw n bolt ... preferably a strong one.... or use a zip tie.... i have em
Old Feb 12, 2006 | 06:22 PM
Mzdarx8's Avatar
The holes were off about 1/8"on mine. I just put the cannister bracket on the heat shield with one bolt and drilled another hole above it.
Old Feb 13, 2006 | 05:10 AM
RX4life's Avatar
had the same problem.. just left it hangin.. checked a week later hasnt budged.. checked it last week and hasnt budged either..so no problems for me...
Old Feb 18, 2006 | 11:08 PM
MadDashRX8's Avatar
Resu Deretsiger
I drilled a new one. Trim a little of the heat shield away from the back in the area of the hole, and you're in business.
Old Feb 18, 2006 | 11:16 PM
what I did was I moved the plastic tube around. take the longer one, put it there. and shorter one back to the end. and it works for me for the past couple of months.
I have no Idea what K&N was thinking, its WAY off the right position. where is the Quality Assurance in the first place ? (their filter setup is good, but this tiny position problem really annoyed me at first ...)
crimson809
Aug 14, 2016 10:03 PM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
