Help installing a switch...
Old Feb 11, 2006 | 07:48 PM
Student Driver
Circular base switches are not a problem to install. Just drill the proper size hole and slip it in...
I have a rectangular shaped base switch that I want to install.
Problem is I have no idea how to cut a rectangular hole to install this switch...
at least with my tools.
Can anyone suggest a fix for my dilemma?
Old Feb 11, 2006 | 07:58 PM
DarkBrew's Avatar
Extraordinary Engineering
http://www.lawson-his.co.uk/scripts/...Hole%20Cutters
Some thing like these simple hole punches would solve the problem.
Old Feb 11, 2006 | 08:08 PM
drill two round holes and file it out with a small file or a dremel....tape around the opening will keep the scratches down
Old Feb 11, 2006 | 08:15 PM
tiggerlee's Avatar
May Cause Anal Leakage
^Yep I think the dremel tool would work the best. If you get one with the circular cutting wheel there may be no need to drill holes.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
