Sway bar question
Old Feb 3, 2006 | 03:22 PM
galleychief's Avatar
Unbalanced & Unmedicated
Sway bar question
I recently had my front and rear sway bars replaced with the Whiteline adjustable set. I opted for the stiffer setting. Now I am hearing a definate thump from the rear end on hard corners at any speed. If there was an issue with the bars
what should I be looking for under the car? Any ideas appreciated, thanks in advance!
GC
Old Feb 3, 2006 | 04:25 PM
Soundave's Avatar
Decepticon
Make sure you didn't install the rear one upside down or anything. If you did, you'll see the apex in the middle of the bar touching (or almost touching) the exhaust. It makes for a noisy and stiff ride.
Old Feb 3, 2006 | 06:38 PM
Spin9k's Avatar
Momentum Keeps Me Going
Make sure you've mounted the lateral movement stops & the bar is positioned laterally as the original was. Note that if the bar is positioned incorrectly, the bar can meet the little articulated level sensor arm on the left side and make noise or damage it.
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Brokegang
Jan 3, 2016 12:45 PM
zoom44
General Automotive
Nov 16, 2015 11:38 PM
WingleBeast
Sep 9, 2015 10:10 AM
