silver_8
02-03-2006, 03:19 PM
Pros and cons about lowering the 8...i got Tien lowering springs...now i'm having second thoughts...help me out guys..thanks!
View Full Version : lowering the 8..pros and cons please! silver_8 02-03-2006, 03:19 PM Pros and cons about lowering the 8...i got Tien lowering springs...now i'm having second thoughts...help me out guys..thanks! Napboy 02-03-2006, 03:27 PM seach nazis, attack!!! just kidding. i have tein s -techs with no ill side effects. doesn't change the ride quality, but you get a boost in the looks department. Animagix 02-03-2006, 03:30 PM new york city roads are the freakin worst. lowering my car was never an option living here. I saw a ricer get stuck over a speed bump.... one of the integras. I couldn't help but point and laugh. MazdaManiac 02-03-2006, 03:41 PM Pros - looks really good. Cons - just about everything else. Seriously though, I've lowered mine quite a bit with the AutoEXE springs and the only penalty is ground clearance. Depending on the condition of your roads, that may or may not be an issue. silver_8 02-03-2006, 03:42 PM seach nazis, attack!!! just kidding. i have tein s -techs with no ill side effects. doesn't change the ride quality, but you get a boost in the looks department. hows the car at high speeds? does the ride still feel smooth? rx8wannahave 02-03-2006, 03:55 PM Yeah, I've thought about this also. Would a slight lower be worth it? I never wanted to lower the car that much...maybe half an inch...what do you all think? khtm 02-03-2006, 03:59 PM Cons: Going over speed bumps is nearly impossible. Pros: You look like you could be in Fast and Furious 3 and high school kids will be impressed. You can start a "Mr. Plow" company in the winter like Homer. STREET RACING IS BAD MK 02-03-2006, 04:02 PM I heard that with the car lower you would be able to take turns faster. sounds like a big plus. chr1s 02-03-2006, 04:03 PM back when I had a mustang I lowered it pretty good. It was my daily driver and it was a major pain in the ass. Always worrying about scraping and having to go 1mph over speed bumps, in the long run it wasn't worth it. I won't lower my rx8 for those exact reasons. If you rx8 isn't a daily driver, then I would definitely go for it, but if this is a car you're gonna be taking to work every day, going to the grocery store, gym, etc...I would just forget it. silver_8 02-03-2006, 04:20 PM HMMM....good point. something ill have to think about. Mikelikes2drive 02-03-2006, 04:22 PM my car is on rb springs and koni shocks... i drive my car on street in southern california and it took a while but i got used to it. I dont mind it at all. silver_8 02-03-2006, 04:32 PM yah cuz im in s. cali too..diamond bar walnut area..roads arent too bad..but im sure it'll take sum gettin used to. thanx! rotaryrocket 02-03-2006, 04:32 PM i lowered mine w/ the tein S tech springs to even out the higher front wheel well gap to the rears. i think the amount of drop w/ these springs is mild so there's no issue w/ ride quality and ground clearance, though personally i feel the 8 corners slightly better w/ the stock springs. also the 8 has camber, cast and toe adjustments built in, so less $ spent for a camber kit, just have a shop do an alignment after the lowering spring get installed. wheelworks did the installation and alignment for $350. call around for pricing, i called 3 local wheelworks and got 3 different prices. silver_8 02-03-2006, 04:44 PM anyone know about a DIY on installing the springs? i cant find it. i tried searching. thanks guys! silver_8 02-03-2006, 05:23 PM i found it. thanks anyways. |
