LEDs and everything about them help?
Old Feb 1, 2006 | 05:05 PM
LiL BenNy's Avatar
Bubblicious? DEF.
Okay so i want to start exploring with LED's anyone know how i can start learning about them? ive seen some wire diagrams but that doesnt help because i dont know what half the words mean..
if im using a LED how do i power it up? i know one goes to the batter and one is ground... but do the mean directly to the battery? also what exactly is "ground"
any tips suggestions or help in the right direction would be greatly appriciated.
Old Feb 1, 2006 | 05:38 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
LED stands for Light Emitting Diode.
They are wired the same way as an incandescent light bulb is.
Old Feb 1, 2006 | 06:00 PM
RotorWheeee's Avatar
04 and still lovin it
Not quite ... A LED is a electrical short , so supplying power to the LED like you would a regular bulb wont work . You have to put a resister in line with it for it to draw power and light .....Ok that's the limit of my knowage
Old Feb 1, 2006 | 06:22 PM
DarkBrew's Avatar
Extraordinary Engineering
A typical LED.
Being a diode current only flows one way under operating conditions. You must have the positive voltage on the anode and the negative on the cathode (usually the flat side) and you must use a resistor to limit the current to about 20 mA. Forward voltage drop is probably between 2 volts and 4 volts. So if you run on 12 volts then you would need (12-4)/0.020A = 400 ohms to (12-2)/0.020A = 500 ohm resistor. (Ohms law)
Look for high intensity LEDs. They come in many colours and vary from thin beams to area lights.
Old Feb 1, 2006 | 06:51 PM
LiL BenNy's Avatar
Bubblicious? DEF.
cool blue.. i basically want to learn to change out my lights that come with my m20 blinder. it comes withe a led turns green when powered on and red when hit. basically i want to make two of these and mount them in my gauge cluster so they are symetrical. now instead of green i want it to be white when powered on and red when im hit, that way it has a more stealthy appearence... kinda like this picture...
Attached Thumbnails LEDs and everything about them help?-instrument-ani-2.gif
Old Feb 1, 2006 | 06:59 PM
True, But wouldn't any LED marked as a 12 volt LED already have the resister built into it?
Old Feb 2, 2006 | 10:58 PM
LiL BenNy's Avatar
Bubblicious? DEF.
i think i get how to wire the led's from looking at a diagram... but how do you connect the power? do you run a wire from the led straigh to the battery or what?
Old Feb 3, 2006 | 09:25 PM
LiL BenNy's Avatar
Bubblicious? DEF.
hey cool do you think you can do this for me? ill pay for supplies plus labor.
Old Feb 6, 2006 | 08:03 PM
LiL BenNy's Avatar
Bubblicious? DEF.
Old Feb 8, 2006 | 09:17 PM
LiL BenNy's Avatar
Bubblicious? DEF.
i live in NJ... wheres corning NY?
RX8mzda
Oct 14, 2015 05:12 PM
CARBONRX-8
Aug 23, 2015 09:52 PM
Stubbs
Jul 28, 2015 09:23 PM
